440 build up
#478509
09/24/09 06:30 PM
09/24/09 06:30 PM
I am just looking to build a 440 for a project short bed truck. I am just wanting to see what some of you have as far as engine upgrades and hp output in your 440. Heads, Cam, Carb, intake, etc
Re: 440 build up
#478510
09/24/09 08:27 PM
09/24/09 08:27 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
.030 over 75 block with 71 steel crank. 76 LY rods, KB 184 pistons with quench that's .004 above deck. Big valve 915 heads. Small summit cam, CH4B intake with a four hole 1 inch spacer and the E-brock 750 carb.
Moparlee
Re: 440 build up
[Re: Robbins]
#478511
09/24/09 08:56 PM
09/24/09 08:56 PM
Nice deal. I have at this point a 72 block with steel crank, 10.5 to 1 ratio, weiand dual plane intake,906 heads, mechanical lifter, 288 duration 492 lift cam, 750 double pumper, and msd ignition. I was looking to see if I just want to refresh or go with aluminum heads and maybe a little different combo. Thats why I want to see what people are building
Re: 440 build up
[Re: Mr.Yuck]
#478513
09/24/09 10:01 PM
09/24/09 10:01 PM
ya, I know what your saying. I just wanted to see some other peoples combos and maybe if they dynoed it what hp torque they made. I am not looking for a ray barton 30,000 dollar combo. Just some everyday guy builds with a little money invested.
Re: 440 build up
#478514
09/25/09 08:31 AM
09/25/09 08:31 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
What is your goal? I ran 12.90 in a basic re-bulid 440. Nothing fancy. .030 440, 9:1 (maybe) 906 heads no port work but 3 angle valve job and 2.08/1.81's, Summit 224-234 465-488 cam. headers, RPM intake, 750DP, 175K convert, 3.91's in a 67 Coronet. Add some more compression, a little more cam, better heads and you have an easy low-12 car you can drive anywhere.
Re: 440 build up
[Re: Mr.Yuck]
#478515
09/25/09 12:11 PM
09/25/09 12:11 PM
Posts: 4,784 Holland MI Ottawa
2boltmain
Holland MI Ottawa
All the components you have mentioned if sound should be good for around 380-400hp. A mopar magazine some 14 years ago built a 440 to 375hp specs. They made 365hp in this stock form. They then added an M1 single plane, holley carb, 509 cam and 1-3/4" headers. With that they hit 420hp.
Keep old mopars alive.
Re: 440 build up
#478517
09/25/09 10:32 PM
09/25/09 10:32 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
