Re: Post your 360 engine combos
[Re: DemonKyle]
#47857
11/10/07 09:52 PM
11/10/07 09:52 PM
Posts: 8,498 Candler,NC / Myrtle Beach, SC
JDMopar
Buy the Summit Racing rebuild kit for a 360.It has good pistons (H405P's),good gaskets,good bearings,and a good price! Buy a Crane 150052 cam and set it at 4 degrees advanced.Use an Edelbrock Performer RPM,RPM Airgap,or an LD340 if you can find one.Use a 1" 4 hole spacer under the carb,and use a decent ignition system.Use stock 360 or Magnum heads with a good 3 angle valve job and good springs matched to the cam. Here's what not to do Don't use KB107 pistons,because they will give too much compression for a street motor.Don't use the cheap Chinese Air Gap intake...they are junk! Good luck kid,and sorry you blew your 318 up.
[Re: DemonKyle]
#47859
11/10/07 10:08 PM
11/10/07 10:08 PM
moparpollack
Lil Herman
Lil Herman
85086
360 crate short block with eddy heads m-1 intake demon carb comp magnum rockers.
[Re: DemonKyle]
#47863
11/11/07 12:22 AM
11/11/07 12:22 AM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
A good one I had: Never measured...the compression could have been b/w 8.2:1 although the guy said they were "9.0:1" pistons (but they were far down the hole...but I digress). Stock 360 heads, 1.88 valves, 3 angle valve job. MP .450/.455 cam, 268/272 duration Edlebrock performer intake (better ones out there...this one was free). Holley 4016 600 cfm carb, electric choke. Hedman headers In a valiant with 4 speed OD manual trans, 2.94 gears this thing started great, idle great in traffic, got as high as 25mpg if you really took it easy on the hwy (typical tank was 18mpg), and even better, went 14.2's all day at the track This was in a 4 door 1976 valiant.
[Re: JDMopar]
#47866
11/11/07 10:04 AM
11/11/07 10:04 AM
Posts: 607 NY
old340dog
NY
There's a cheap Chinese version of the air gap out there?Is there anything these guys don't try to copy. Who makes its and who sells it? guess I want to make sure I don't get one of these on my rebuild.
old340dog
