Lost a few Pounds #478431
09/24/09 05:45 PM
09/24/09 05:45 PM
SC
Greg Offline OP
Greg  Offline OP
SC
No not me, I am still overweight! Had the car soda blasted and lost four coats of paint along with a load full of bondo. New wheel lips and rear drivers lower quarter panel will be going on. I will update more pictures as they become available.
Re: Lost a few Pounds [Re: Greg] #478432
09/24/09 05:54 PM
09/24/09 05:54 PM
SC
Greg Offline OP
Greg  Offline OP
SC
Another
Re: Lost a few Pounds [Re: Greg] #478433
09/24/09 05:59 PM
09/24/09 05:59 PM
SC
Greg Offline OP
Greg  Offline OP
SC
Front
Re: Lost a few Pounds [Re: Greg] #478434
09/24/09 06:04 PM
09/24/09 06:04 PM
SC
Greg Offline OP
Greg  Offline OP
SC
Trunk Lid
Re: Lost a few Pounds [Re: Greg] #478435
09/24/09 06:07 PM
09/24/09 06:07 PM
SC
Greg Offline OP
Greg  Offline OP
SC
Ugly Side
Re: Lost a few Pounds [Re: Greg] #478436
09/24/09 06:11 PM
09/24/09 06:11 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
What kind of old wheels are those? Did you find someone locally to your area to do the blasting...Its good to know, your not that far from me..
Re: Lost a few Pounds [Re: Bob_Coomer] #478437
09/24/09 06:14 PM
09/24/09 06:14 PM
Q
Quicktree Offline
Quicktree  Offline
Q
how did you find the blaster? been looking for a local blaster for my sons car.
Re: Lost a few Pounds [Re: Quicktree] #478438
09/24/09 06:18 PM
09/24/09 06:18 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Tony may not be local but the guy that did mine here in Orlando did a great job and was reasonable on price and is a mopar guy.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Lost a few Pounds [Re: Bob_Coomer] #478439
09/24/09 06:29 PM
09/24/09 06:29 PM
SC
Greg Offline OP
Greg  Offline OP
SC
They are older Monocoque wheels. Brad Spurlock is the soda blaster and is located in the Charleston, WV area and has a mobile unit. I would not suggest to soda blast a car that was together. The soda gets in every corner or crevice. Brad blew it out with his compressor but I still used a shop vac and blew it out a few more times. Do your homework on the prep after soba blasting also. The soda leaves a film that you have to clean off before applying a sealer. There have been issues with primer not adhering if not prepped correctly. There is a company that makes a prep that is called Holdtight 102 that guys are using and I just ordered a gallon.
The soda blaster said that all you had to do was clean the panels with warm water and dawn detergent but I am not taking any chances. I don't have extra money to blow on sealing the car twice.
Re: Lost a few Pounds [Re: Greg] #478440
09/24/09 06:39 PM
09/24/09 06:39 PM
SC
Greg Offline OP
Greg  Offline OP
SC
I looked for quite some time trying to find someone that soda blasted in my area. I would suggest to talk to some of the car restoration or rod shops in your area to see if they know of someone. I called a Charleston powder coating company and they referred me to this guy. Fortunatly he lived only about 60 miles from me and had a mobile unit and he did it on a pad next to my detached garage. If you live close to other houses don't even try it because it does creates a lot of soda dust in the area depending upon the wind.
Re: Lost a few Pounds [Re: Greg] #478441
09/24/09 07:40 PM
09/24/09 07:40 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Enquiring minds want to know ... what's a job like that cost?
I've seen where they go over the whole car afterwards with scuff pads in angle grinders to prep the surface after soda blasting however I've always been curious about how they scuff all the nooks and crannies. Maybe the soap thing would be better after all. And then doesn't the water dissolve the soda, so you wouldn't have to worry about any loose stuff.
Re: Lost a few Pounds [Re: Stanton] #478442
09/24/09 07:50 PM
09/24/09 07:50 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
DO NOT USE DAWN SOAP, it will start to rust with in an hour if you do!...Phill
Re: Lost a few Pounds [Re: 9 Sec Phill] #478443
09/24/09 08:06 PM
09/24/09 08:06 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Re: Lost a few Pounds [Re: Stanton] #478444
09/24/09 08:17 PM
09/24/09 08:17 PM
SC
Greg Offline OP
Greg  Offline OP
SC
It varies depending upon where you live. It is around $700.00 to $850.00 for the exterior of the car. If they are doing the inside and the undercarriage the price is around $1300-$1500 locally. The guy that soda blasted mine does not do the under carriage unless it is on a rotiserrie. If you decide to get a car soda blasted do it by the job and not by the hour. The soda blaster kept on telling me that my car was toughest he had ever ran into for getting the paint off. It usually takes a guy 5-8 hours to complete a mid size car. It took the soda blaster two visits and around 12-13 hours due to 4 coats of paint and the thickness of bondo on drivers side.
Re: Lost a few Pounds [Re: Stanton] #478445
09/24/09 08:21 PM
09/24/09 08:21 PM
SC
Greg Offline OP
Greg  Offline OP
SC
Check this out:
http://www.crankshaftcoalition.com/wiki/Soda_blasting
I read that article and it was one of the reasons I went with the holdtight 102. It is all about the prep after soda blasting.
