Post deleted by Defbob
[Re: rickstershemi]
#478361
09/24/09 05:42 PM
09/24/09 05:42 PM
Re: 727 or Poweglide ???
#478362
09/24/09 05:47 PM
09/24/09 05:47 PM
Posts: 2,864 IN
Irun5snd8th
IN
A well built glide will definitely hold up in a car that heavy. I would say a 1.80 straight cut gear would be good idea though.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Irun5snd8th]
#478363
09/24/09 05:51 PM
09/24/09 05:51 PM
#478364
09/24/09 06:03 PM
09/24/09 06:03 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
ay 3900 t-400 Would be my choice still stronger and cheaper than 727
Definitely T-400 with that heavy of car, definitely.
#478365
09/24/09 06:14 PM
09/24/09 06:14 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
3800-3900? Little heavy for a glide, I think.
YUP
Rickster
nope unless your an ET chaser . still ok for brackets
do some research
Have and wouldn't run a 2-speed in any car that heavy....even bracket racing
I do agree on the T-400 though
Rickster
[Re: rickstershemi]
#478369
09/24/09 06:44 PM
09/24/09 06:44 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I just don't get it. Everyone wants to abandon the 727. You can go to a transmission parts supplier and get a clutch and seal kit for $100. Buy a billet drum for safety and a truck planetary for reliability. The two will cost $1,000. If you don't already have a good valve body then that is why you have burnt clutches. Tranzact would be my choice. Any Mopar junkie who has built their own 727 successfully can easily handle the build.
Ask your self this simple question. If torqueflites are such a peice of crap then why do the majority of comp guys run them even in the Chevies?
But, If you want a great powerglide I have two to choose from. With more tricks than you can imagine in them. Be glad to sell you one or even both of them.
Leon
[Re: moparmanjames]
#478372
09/24/09 07:15 PM
09/24/09 07:15 PM
Posts: 258 Stockholm, Sweden
TomsCharger70
Stockholm, Sweden
Hmm, could be the torque converter if you lost all gears.
1st gear worked for a little while, just enough so I did not have to push the car into the garage. But I had to rew the engine really high to get the car moving and keep rews high to keep it moving..
The whole thing happend on my way to the race track. It is a 60mile highway drive. I have a trans cooler, etc..
[Re: moparmanjames]
#478373
09/24/09 07:15 PM
09/24/09 07:15 PM
[Re: TomsCharger70]
#478375
09/24/09 07:54 PM
09/24/09 07:54 PM
#478376
09/24/09 08:03 PM
09/24/09 08:03 PM
Posts: 705 Michigan
Hemiroid
Hmm...
CRT Super pro II with transbrake 3640$ + shiping
ATI Pro Glide + Adaptor case 3720$ + new converter + new driveshaft + shiping
any questions???
Yeah, you forgot to mention that to get an equal to the Pro-flite you need a $7000 Rossler. I really don't understand why the push to convert everyone that mentions a 727 to gm transmissions.
[Re: Hemiroid]
#478377
09/24/09 08:33 PM
09/24/09 08:33 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
I hate to say it, go with the glide, my car is all confused, 9" in back and a glide inda middle, all Mopar motor.
[Re: Hemiroid]
#478378
09/24/09 08:37 PM
09/24/09 08:37 PM
#478379
09/24/09 08:56 PM
09/24/09 08:56 PM
Posts: 705 Michigan
Hemiroid
Not True or even close.like apples to oranges. at 5500.00 plus a proflite is usually chosen for it's many gear ratio , less reciprocating weightcan only handle 1300 hp aso known for a short lifespan. the 5500.00 Rossler is built to handle 2000 + pro mod hopsepower
a basic stock with good clutces and bands 400 can handle about 700 Hp amd coss arond 1200.00. step up to some better drums good to 1100 hp
Fred,
To get a 210exd with all of the trick, lightweight goodies equal to a PF it approaches $7000. Yes, in a 2000 hp pro-mod I agree that the Rossler is the only choice. That being said, I'm pretty sure he doesn't have a pro-mod nor was one mentioned. He says he has a 650hp hemi that he'll occasionally squirt. Also, that price you quote from Rossler is without an Ultra-Bell, the crank adapter and the chevy flywheel. Then get a new driveshaft, slip yoke and fab a trans mount. Lets not get it twisted.
[Re: TomsCharger70]
#478380
09/24/09 09:04 PM
09/24/09 09:04 PM
Posts: 5,989 Anoka County, MN
Leigh
Anoka County, MN
The powerplant is a 426 Hemi, should be good for 650Hp, plan is to add a 2-300hp shoot of Nitrous later on.
Steel front planet, steel or aluminum front clutch retainer, roller planets and output support, 4340 pump gears, preferable year front pump hsg and reaction shaft support and low band apply valve body. Zyglo the input and output shafts. Wala, you're good to go.
edit: I didn't notice he was going to giggle gas.
[Re: Hemiroid]
#478382
09/24/09 09:09 PM
09/24/09 09:09 PM
[Re: 440Jim]
#478383
09/24/09 09:10 PM
09/24/09 09:10 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Good question to ask, and only you can decide.
I love my 727. Since I do my own work it is very cheap and holds up to the power well. To be fair, a PG would likely be a better bracket race setup in my car (3200 lbs), but my consistancy is as good as anyone in my class.
I say to stay with the 727 and put a better valve body in it. Either the Tranzact or Griner. I expect you already have a billet front drum for safety. If you have a transbrake, then put a steel spline front planetary in the trans. I run footbrake and a stock 4 pinion aluminum body planetary.
How much power are you making Jim, and how many passes until you have to freshen it up?
#478385
09/24/09 09:24 PM
09/24/09 09:24 PM
Posts: 705 Michigan
Hemiroid
HEMIROID. not twisted just clearing up your statement Quote:
the two can't be compared.
I hear ya Fred. I agree that with 2000hp stuff the 400 is more durable, but not in his case IMO. The point I was trying to make was that a $7000 PF has every trick part known to man in it To get the same lightweight, trick geared 400 it costs the same money, and the PF is still faster. That 400 will handle a lot more hp, especially above 1000hp, but that wasn't the discussion that was being had. Peace
[Re: Leigh]
#478387
09/24/09 09:49 PM
09/24/09 09:49 PM
#478389
09/25/09 06:55 AM
09/25/09 06:55 AM
moparmanjames
Las Vegas NV
Hmm...
any questions???
Yes, arent these way too much money and transmission for what he's doing? Especially since he's driving it on the highway to the racetrack?
