Re: Sudden loss of oil pressure in 440.
[Re: stumpy]
#478176
09/24/09 01:02 PM
09/24/09 01:02 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
DOH! I feel stupid, I missed where he said that. Stumpy is correct, No electricity to a mechanical guage. Disconnect the guage from the tube and start the car for a few seconds. Oil should come out of the tube. If not you got problems, could be a bad tube but more than likely a bad oil pump drive since the problem just popped up. If oil comes out then try a new guage you trust. If the pressure is still low/none then check the oil pump drive for rounding off.
[Re: IMGTX]
#478177
09/24/09 01:19 PM
09/24/09 01:19 PM
Posts: 2,165 Inver Grove Heights MN
74RR
The tube and gauge are very old.I used both of these ( tube and gauge on two different vehicles for the 17/18 yrs.
How much oil should I look for coming out of the end of the hose when I fire it up?
Oil pump drive? Is that the shaft between the dist and oil pump? I bought mine new from 440 source.
[Re: 1_WILD_RT]
#478182
09/24/09 06:10 PM
09/24/09 06:10 PM
74RR
Possibility #1 Lifter out of it bore... Possibility #2 Stuck oil pressure relief valve... Possibility #3 Broken drive...
It looks like a lifter popped out of it's bore. I pulled the drivers side rocker cover and noticed rightaway that the intake pushrod on the #1 cylinder was way down in the "pushrod guide". Now what do I do? How does a lifter pop out like that,will it happen again?
[Re: maximus]
#478183
09/24/09 06:33 PM
09/24/09 06:33 PM
74RR
Once I loss a lifter when a pushrod broke, pressure went down to 5-10 lbs. Made it home with really no noise in motor. Opened the top, just had to put the lifter back in the bore and a new pushrod.
Yep this is what happened to me. I can't even get the bent rod out. I'm going to have to tear the topend down.
