La heads on Magnum block?
#478140
09/24/09 09:49 AM
09/24/09 09:49 AM
Posts: 401 Berlin, Germany
Flo
Berlin, Germany
HI, after eventually destroying my 318 block I am looking around for a 360 with roller lifters to bolt my (LA) Edelbrocks on. Is there a way to make this work with a Magnum? Are the MAgnum 360 still externally balanced? Any way like that flexplate which is out there for the LA 360 tu run neutral converter? Alternatively I would use an older 360 and need to get the retrofit roller lifters - really want a roller cam! Greets flo
1967 Fury III 4door HT
tiny 318, late model roller block, bored and stroked to 344
Re: La heads on Magnum block?
[Re: Flo]
#478141
09/24/09 10:05 AM
09/24/09 10:05 AM
RapidRobert
you can drill horizontally into the back of the LA head(s)then up top slightly countersink drill part way down in the threads on the rear pedestal so you have a place to start drilling downward at an angle to meet the horizontle passage. feed it from the extra oil passage at the rear of the block that is currently plugged & T off of it to feed both heads. EDIT when I typed pedestal I meant the LA rocker stand to avoid confusion.
[Re: RoyceFlo73]
#478143
09/24/09 11:23 AM
09/24/09 11:23 AM
Flo
Berlin, Germany
but there is a flex plate which will do it?
[Re: RoyceFlo73]
#478146
09/25/09 07:32 AM
09/25/09 07:32 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
And to further clarify - weld them on the flexplate, not the converter.
If the converter is a lockup model the welds will fall on the region the clutch applies. The welds will cause some distortion in those areas and could damage the clutch when it applies.
OEMs weld the lugs on and then machine for the clutch surface.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Fury Fan]
#478147
09/25/09 09:24 AM
09/25/09 09:24 AM
Flo
Berlin, Germany
could not find a pre Magnum roller 360 yet... that would make a lot of things easier...
[Re: Flo]
#478148
09/25/09 11:12 AM
09/25/09 11:12 AM
Posts: 374 CONNECTICUT
RoyceFlo73
CONNECTICUT
I'm gonna hi-jack the thread for one question. Is the magnum engine and the LA 360 roller have pedestals for the the rockers or does one have a common rocker shaft? If there is a difference there would be the reason for me to pick one over the other. Alright, i'm done. You can have it back now.
[Re: RoyceFlo73]
#478149
09/25/09 11:32 AM
09/25/09 11:32 AM
Posts: 2,826 NY usa
540challenger
NY usa
LA roller 360 like all LA engines is a shaft mounted rocker
Magnum pedestals.
Magnum's main advatage is in the head better flowing, better combustion chamber and 1.6 rockers
LA lots of intake choices and aftermarket head choices compared to the magnum
[Re: scratchnfotraction]
#478151
09/26/09 12:06 PM
09/26/09 12:06 PM
Flo
Berlin, Germany
is ther any offer out there for a short block with rolelr lifter provisiosn and LA oiling and the pistons at zero deck? The MP 360 shortblock would be great but if I understand it correctly pistons are 040 below deck...
[Re: Fury Fan]
#478152
09/26/09 12:13 PM
09/26/09 12:13 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
On a magnum 5.9 the weights are on the flex plate not the converter so all you have to do is makesure the flex plate is on the motor when you pick it up from the junk yard. You will have to use the newer style starter with the newer flex plate but they are way better anyhow.
[Re: 70AARcuda]
#478154
09/28/09 04:23 AM
09/28/09 04:23 AM
Flo
Berlin, Germany
current Mopar Performance catalog list p/n 5153907 which acc. to the table should have pistons 020 below deck... would like to verify that with someone Greets Flo
