Carter 750 AFB 9755S bog off idle problem #478107
09/24/09 08:23 AM
09/24/09 08:23 AM
Anonymous OP
Anonymous OP
im running 2-4bbl's on a new indy legend offset crossram intake, i just started getting a wicked bog off the line, i switched to a different set of carter carbs and bog is gone.
so i know theres a problem with one of the carbs.
i suspect a lean condition or lack of fuel at takeoff.
as soon as the carb gets through the bog, the carbs run fine.
Where do i look 1st to fix the problem.
im thinking squirters or primaries.
Re: Carter 750 AFB 9755S bog off idle problem #478108
09/24/09 08:26 AM
09/24/09 08:26 AM
Anonymous OP
Anonymous OP
the bog is with .113 square jets with 6849 metering rods.
no bog is with .116 jets and 6849 metering rods, i dont believe the problem is with metering jetting.
Re: Carter 750 AFB 9755S bog off idle problem #478109
09/24/09 09:49 AM
09/24/09 09:49 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I,m a holley guy,but sounds like not enough or lack of "SQUIRT" from accellerator pump.Lack of SQUIRT can be a problem for sure
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Carter 750 AFB 9755S bog off idle problem #478110
09/24/09 01:42 PM
09/24/09 01:42 PM
Check the pumps on both sets of carbs on the motor, make one squirt as you watch both carbs, one at a time of course I have had a Carter carb role the side of the squirter skirt over which resulted in a partial squrt out of that carb (Max Wedge motor ) Also look at the anti drain back valve in the side of carb accelerator pump well, they will get stuck open once in a while, especailly if they sit with fuel in them a lot often and the fuel evaporates and leaves a stinky residue The last thing to check is the check valve under the squirter, make sure it is in there and it is loose so it will work properly
Re: Carter 750 AFB 9755S bog off idle problem [Re: Cab_Burge] #478111
09/24/09 02:17 PM
09/24/09 02:17 PM
Anonymous OP
Anonymous OP
thanks Cab, i blew out the squirters, replaced acceerator pump , made sure check valve is moving, now i got squirters working again, thanks.
