Dynoed the Dart today.. #477847
09/23/09 09:07 PM
09/23/09 09:07 PM
mid Ga.
W5Dart378 Offline OP
mid Ga.
Last time with W5s it was 555hp ,460tq.
Today with Chapman W9s it made 606hp, 490tq.
Same bottom end, camshaft and carb. Peak power and torque were 500rpm higher with the W9s.
How does this sound? 422" X block.
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s 69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
Re: Dynoed the Dart today.. [Re: W5Dart378] #477848
09/23/09 09:42 PM
09/23/09 09:42 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
sounds good to me! Real good!
Re: Dynoed the Dart today.. [Re: W5Dart378] #477849
09/24/09 09:22 AM
09/24/09 09:22 AM
NC
440Jim Offline
440Jim  Offline
NC
I think you will feel the 50 hp difference when running all motor!
Re: Dynoed the Dart today.. [Re: 440Jim] #477850
09/24/09 09:42 AM
09/24/09 09:42 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Whats the compression ratio and cam?
Re: Dynoed the Dart today.. [Re: W5Dart378] #477851
09/24/09 11:01 AM
09/24/09 11:01 AM
Just out of curiosty was that on a engine dyno or chassis dyno? Either way that is a good gain
Re: Dynoed the Dart today.. [Re: emarine01] #477852
09/24/09 11:06 AM
09/24/09 11:06 AM
mid Ga.
mid Ga.
It's 13:1 now, was 12:1 with the W5s.Camshaft is a Bullet Roller 276/282 around .670",109 lsa in at 104.5.
Made 600hp from 7000-7500.
peak torque is 5800-5900.
I have made about 20 passes with it but all were with a tighter converter and a tall deck W9 intake.Dyno passes were with a new 420 intake,wish I could have conpaired the intakes..
Re: Dynoed the Dart today.. [Re: Cab_Burge] #477853
09/24/09 11:12 AM
09/24/09 11:12 AM
mid Ga.
mid Ga.
Dynojet chassis dyno.
What is the conversion factor to figure crank hp?
Re: Dynoed the Dart today.. [Re: W5Dart378] #477854
09/24/09 11:17 AM
09/24/09 11:17 AM
I don't know, sorry I'm sure someone will add it onto here soon I have heard anywhere from 15 to 30 % loss due to drive train friction Those are some stout numbers, very impressive
Re: Dynoed the Dart today.. [Re: W5Dart378] #477855
09/24/09 11:32 AM
09/24/09 11:32 AM
Charlotte NC
cudadave72 Offline
cudadave72  Offline
Charlotte NC
Stupid question... Is an X block an older version of an R3 block??? Sounds like it holds alot of power.
