Need 340 main caps... #477547
09/23/09 02:00 PM
09/23/09 02:00 PM
Phoenix, Arizona
HerboldRacing Offline OP
Phoenix, Arizona
This is for building my W5 headed 340 race motor. I think I found some 340 blocks in pretty good shape but they are missing all the main caps. Does anyone here have at least the rear and front main caps for a 340 that they want to get rid of or sell to me? Thanks!
Marvin Herbold 1973 Plymouth Duster 340 Drag Car Blog - http://www.HerboldRacing.com Videos - http://www.YouTube.com/mherbold Pictures - http://gallery.herbold-family.com/main.php?g2_itemId=10331
Re: Need 340 main caps... [Re: HerboldRacing] #477548
09/23/09 03:21 PM
09/23/09 03:21 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I would consider getting the aftermarket caps while you are machining the block. The 318 are similar, but a little smaller on the center caps. I think the pump cap might be the same, but I haven't measured them.
http://www.pro-gram.com/catalog.jsp
http://www.milodon.com/main-caps/main-caps.asp
Floyd Lippencott IV
Re: Need 340 main caps... [Re: HerboldRacing] #477549
09/23/09 03:26 PM
09/23/09 03:26 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
318 ones are the same but you will have to check line bore and hone.
Buy these 318/340 ones on the lower left 5.2/5.6 in French
http://chucker54.stores.yahoo.net/mabesp.html
AKA dodgeboy8
Re: Need 340 main caps... [Re: Dodgem] #477550
09/23/09 03:59 PM
09/23/09 03:59 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I built a 318 about 25 years ago and put a 340 windage tray and used the DC bolt kit. The tray hit the crank and I had to use two flat washers under the head of the 2/4 capscrews. I measured those caps later when I replaced it with a 340 and found the cap to be about 1/8" shorter at the bolt surface. I haven't had any 318 engines since, nor measured any caps. Based on one 318 block and one 340 block, that's what I found.
Floyd Lippencott IV
Re: Need 340 main caps... [Re: mr_340] #477551
09/23/09 07:30 PM
09/23/09 07:30 PM
New Zealand
solidcam Offline
solidcam  Offline
New Zealand
As MR340 mentioned the factory 340 caps do have a little more beef to them; the rear cap I have never measured but looks identical to the 318 cap.Bearing in mind that any 340 caps are likely to be 40 years old any only offer a tiny margin of additional support I would go straight to the aftermarket and obtain a superior product in every way.( I wish I had ditched my 340 caps when I set my 340 up;live and learn)
Re: Need 340 main caps... [Re: Dodgem] #477552
09/23/09 07:41 PM
09/23/09 07:41 PM
Phoenix, Arizona
Phoenix, Arizona
Thanks for the link Dodgem / dodgeboy8. :-)
For the middle 3 I am definitely going with 4 bolt angle caps. I found someone that had a full set of all 5 caps so I bought them from him.
Re: Need 340 main caps... [Re: HerboldRacing] #477553
09/23/09 09:02 PM
09/23/09 09:02 PM
if that's a factory block, i wouldn't recommend doing that. all your doing is creating another stress riser from where the bolt holes break through and from the cut threads you'll be putting in there.
Re: Need 340 main caps... #477554
09/24/09 07:55 AM
09/24/09 07:55 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
two bolt caps with studs
