valve cover gaskets #477235
09/23/09 03:50 AM
09/23/09 03:50 AM
campbell river B.C
mopartoby Offline OP
campbell river B.C
is there anyone making a decent set of bb valve cover gaskets? i've had the silocone steel ribbed one's on my small block for 13 yrs with no problems. i'm building a 528 for a customer and i would really like to use something other than cork or thin rubber.
thanks
Re: valve cover gaskets [Re: mopartoby] #477236
09/23/09 07:15 AM
09/23/09 07:15 AM
KY
juicedcuda Offline
juicedcuda  Offline
KY
Use the moroso blue gaskets. Well worth the money.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: valve cover gaskets [Re: juicedcuda] #477237
09/23/09 07:50 AM
09/23/09 07:50 AM
x2.. but on a small block,the mopar ones were good but the Moroso's are great, cheaper too..
Re: valve cover gaskets #477238
09/23/09 10:13 AM
09/23/09 10:13 AM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
The FelPro vs50145r is another option.
This space available for rent
Re: valve cover gaskets [Re: cptn60] #477239
09/23/09 10:15 AM
09/23/09 10:15 AM
Madison WI
Sublime69 Offline
Sublime69  Offline
Madison WI
It seems I just bought a set of Hi-Temp Fel Pro gaskets from Autozone, they work really good. Had the valve covers off several times, never ripped, leaked etc.
1969 Dodge Superbee - Original plain jane green 318 Coronet now Sub-Lime, 383 4 speed clone.
Re: valve cover gaskets [Re: juicedcuda] #477240
09/23/09 11:00 AM
09/23/09 11:00 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The rubber Moroso`s didn`t last long for me as they tore along the outer edge w/ e-heads but, there is a fairly sharp edge on these heads so maybe w/a bit of fileing they might not tear. I use fel-pro cork gaskets and personally have better luck.
Re: valve cover gaskets [Re: Thumperdart] #477241
09/23/09 11:09 AM
09/23/09 11:09 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Same thing happened twice on my E heads with the Moroso's. Split along the outer rail at the headers.
I've gone back to the orange Mopar's #4027092 and RTV them to the cover (Aluminum 440 Source ones).
No leaks now.
