axle bearing replacement ???? #476973
09/22/09 08:32 PM
09/22/09 08:32 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Has anyone ever had this happen?
I am replacing an axle bearing at work and I set it off to the side for when I had some free time.
A co-worker decided to help me out and took it to his work area.He was using a cut-off wheel to grind the collar,so that the bearing could come off.
He accidentally ground too deep and now there is a nick in the axle about 1/16 deep and about 3/8"
long.
This is a stock axle behind a warmed 383 4-speed,with a 4:10 gear.I drive it pretty hard and it will see limited track time.
Would you press a new bearing and seal on it and forget about it? I'm sure this is not the first time it's happened to someone grinding the collar,I don't know if it severely weakens that area or not.
Re: axle bearing replacement ???? [Re: jcastle1] #476974
09/22/09 09:32 PM
09/22/09 09:32 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
I've done the same thing. Put it together and run it w/no problems.
Re: axle bearing replacement ???? [Re: Bill MeLater] #476975
09/22/09 10:55 PM
09/22/09 10:55 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
At what point would you suggest a replacement axle and not use this one ?
Re: axle bearing replacement ???? [Re: jcastle1] #476976
09/23/09 08:23 AM
09/23/09 08:23 AM
scratchnfotraction Offline
when it brakes,replace it
never seen one brake on that end,allways at the splines and from twisting
if your buddy is going to replace it,then by all means,do it now
Re: axle bearing replacement ???? [Re: jcastle1] #476977
09/23/09 03:42 PM
09/23/09 03:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I, too, would use it but I'd take a fine grit rotary stone and dress any sharp edges.
Re: axle bearing replacement ???? [Re: John_Kunkel] #476978
09/24/09 05:40 PM
09/24/09 05:40 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Thanks for the replies.I ended up smoothing the edges and pressed a new bearing and collar on it and bolted it back in the car.-john
