Carter TQ 9800S performance tune setup.... #476584
09/22/09 12:50 PM
09/22/09 12:50 PM
Windsor, ON, Canada
Diplomat360 Offline OP
Windsor, ON, Canada
Looking for recommendations on setting up the aftermarket Carter TQ 9800s carb. This a GM style throttle bracket, non-EGR carb with the electric choke setup.
I picked up a NOS piece, have it apart right now. I'm very familiar with these carbs, what I am looking for are specific hints/tips on how the 9800 series setups may be different from a typical TQ carb. This is the first 9800 series carb that I am working with.
Carb has 0.095 primary jets, 0.137 secondary and 2110 rods. This is going on a 360 motor, about 400hp, nothing crazy, a mild small block. Motor is running a Hughes 3844 hydraulic cam (238/244 dur @.050, .515/.536 lift), 108 LSA. Heads flow 262 @ .550, using Performer RPM intake with an adapter plate (spreadbore to squarebore). 3000 stall converter, 727 tarns, 3.91 SG rear end in my M-body coupe.
Thanks!
Re: Carter TQ 9800S performance tune setup.... [Re: Diplomat360] #476585
09/22/09 01:01 PM
09/22/09 01:01 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
it was sugested on my 850cfm tq with choke removed to go with .100 pri/ .154 to .157 sec/ i have 1966 rods, this was for a 360 like yours 400 hp but with the stock intake
