Re: 727 manual valve body questions
[Re: biggerredz71]
#476574
09/22/09 01:11 PM
09/22/09 01:11 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
If they said they would fix it how is that giving you the run around?
[Re: biggerredz71]
#476576
09/22/09 01:21 PM
09/22/09 01:21 PM
WILD BILL
BROOK PARK, OH
If you drop the pan the VB may have a # scribed in it. All my TA's have had them.
Does it still have the kickdown linkage attached? MVB's don't require it so I would question it if it was there.
I don't suppose you have a known good VB to swap in for a test?
[Re: Dodgem]
#476578
09/22/09 02:22 PM
09/22/09 02:22 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
Is this a forward pattern manual VB ? If so, the gov circuit is internally connected but can sometimes cause trouble if you add a rollerized rear support and the gove circuit in the case leaks to lube oil. AG
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: biggerredz71]
#476580
09/22/09 03:26 PM
09/22/09 03:26 PM
Posts: 25,790 Rio Linda, CA
John_Kunkel
Rio Linda, CA
To clarify, if it is a true MVB you should be able to place the shifter in D and it will take off in 3rd gear. If you place the shifter in 2 it should take off in 2nd. Does it?
[Re: biggerredz71]
#476581
09/22/09 03:29 PM
09/22/09 03:29 PM
turbobitt
Southington Ct.
I had a problem like this because of my statement above. Do you know if you have a rollerized rear support ? If so, you are lossing gov pressure in the rear lube circuit. The easiest way to fix this is to dissassemble the VB and seperator plate and JB weld around the supply and return gov passages in the lower casting. I done this before but don't have any pictures. Allan G.
