Pro Tree- How do you deal with it? #476461
09/22/09 10:34 AM
09/22/09 10:34 AM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Ran a couple index races on a pro tree light this year and it seemed I was late more often than not.
The last pass, I decided to take a shot at the tree, staging only slightly deep, but limiting myself by thinking "click-bang" when both cars were staged. I guess I got a little anxious and just went bang, and of course red.
So my question is what methods do others use, and what is the standard(if any) delay between the starter pushing the button and the light.
Yeah, it's got a smallblock.
Re: Pro Tree- How do you deal with it? [Re: 340B5] #476462
09/22/09 11:34 AM
09/22/09 11:34 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Foot brake or tranz brake?
Re: Pro Tree- How do you deal with it? [Re: 340B5] #476463
09/22/09 11:34 AM
09/22/09 11:34 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Shorter front tires at max air pressure.
Limit front end travel.
Higher launch rpm.
If trans brake, use fastest button you can get.
When you stage, be amped up and don't think about or look at anything but that tree.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Pro Tree- How do you deal with it? [Re: nhramark] #476464
09/22/09 12:03 PM
09/22/09 12:03 PM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
Higher launch rpm.
X2. I had my first heads up final a couple weeks ago, and wanted it bad! .026 light and the win.
Usually 2 seconds from when the starter sees both staged, but I wouldn't sit there and count, just concentrate, like is mentioned above. If your good you can also bump in further, but be careful and expect a slight loss in ET.
Re: Pro Tree- How do you deal with it? [Re: 4404dart] #476465
09/22/09 12:07 PM
09/22/09 12:07 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Depends on how quick your car reacts. This year starters are a little slower on hitting the button, making it harder to take a shot at the tree and get a green light. At KCIR 2 weeks ago, I had to reds in qualifying, and I saw the yellows flash before I let the button fly. A friend who was on the line said that the altered picked the tires out of the beam on the second pass.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Pro Tree- How do you deal with it? [Re: Slingshot383] #476466
09/22/09 12:19 PM
09/22/09 12:19 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I think the autostart is set around 2.5 seconds, it will vary +/- 0.1 to deter cheating.
A manually thrown starter switch is totally up to the individual starter, years ago when I was running S/ST, some whiner accused our starter of collaborating with me, as I was getting good lights on the .500 pro tree off the footbrake.
As was said before, being totally focused after lighting the 2nd stage bulb is the key. Go to TNT and get as many hits as you can. After 8-10 hits staging shallow, try rolling in a few inches. A practice tree is a good tool, also.
Re: Pro Tree- How do you deal with it? [Re: 4404dart] #476467
09/22/09 12:23 PM
09/22/09 12:23 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Foot braking on this; I have an 8 3/4, so I don't want any explosions. I need to limit myself somehow so I might stick to the click-bang method, but yeah too much thinking can get you in trouble at that point. Trans brakes are allowed, but no delay boxes. The t-brakes are hard to beat, but at least the car goes home in one piece. Thanks for the tips.
Re: Pro Tree- How do you deal with it? [Re: cgall] #476468
09/22/09 12:32 PM
09/22/09 12:32 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Practice tree might be a good idea! At least there's a T&T the day before the next index race.
Re: Pro Tree- How do you deal with it? [Re: 340B5] #476469
09/22/09 03:46 PM
09/22/09 03:46 PM
Lehigh Acres, Florida
rickstershemi Offline
I can only imagine foot braking a .400 tree as being extremely difficult
Rickster
Re: Pro Tree- How do you deal with it? [Re: rickstershemi] #476470
09/22/09 03:58 PM
09/22/09 03:58 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Rickster
exactly, with a low hp heavy car forget it.
Re: Pro Tree- How do you deal with it? [Re: Quicktree] #476471
09/22/09 06:40 PM
09/22/09 06:40 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I ran on a .400 Pro Tree last year and I staged as I would on a full tree shallow staging. No matter how hard I tried with my 3700 lb full body mid 11 car the best I could do was 1.010. There was another guy there running a 63 Ply wagon running about the same mid 11's as me and he wins alot as he deeps stage to cut a good lite. He looses about a tenth off his et doing that but its works fine as the group he runs with dails on the 1/2 second. I was just there playing around but foot braking a very mild mid 11 leaf spring car is very hard to get a lite on a .400 Pro Tree without deep staging. And I dont think all the groups let you deep stage. Ron
Re: Pro Tree- How do you deal with it? [Re: 4404dart] #476472
09/22/09 08:05 PM
09/22/09 08:05 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Higher launch rpm.
X3 I havent done any of the above except the concentrate on the tree, my reaction ranged from .074 to a .095 with no changes to the car, I am sure it would be much tighter if I did the thing's on the list.
Re: Pro Tree- How do you deal with it? [Re: dartman366] #476473
09/22/09 08:11 PM
09/22/09 08:11 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Ran pro tree last weekend for the first time. I was an avid bracket racer for years, and I already knew about the tire pressure and such. I kept hitting .520 lights on the tree just bumping the car in with the tire pressure about as high as I would go, then I started staging a little deeper, and finally got a .499 and then 1st round a .480 light. Tires were about half way in, but not deep staged. So .480 off the foot brake first time out, not so bad.
Re: Pro Tree- How do you deal with it? [Re: Dragula] #476474
09/22/09 10:30 PM
09/22/09 10:30 PM
Practice tree did wonders for me. I know guys have all kind of opinions.
My 2 cents, and once you get it down, you will understand what I mean.
You must train your eye to talk directly to your thumb, toe, bicep, whatever you need to move.
I mean literally bypass your brain, because if your eye tells your brain to move your thumb, it's too late.
It's amazing how much I learned with a cheap $100 practice tree.
I went from high high .400's to being able to red light once in awhile. Good luck.
Re: Pro Tree- How do you deal with it? #476475
09/23/09 01:38 AM
09/23/09 01:38 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
down our way the starter has been given a wind up about releasing the tree too slow so now as soon as both lanes have staged he drops his thumb. i use this to my advantage by staging first & going in deep(2xapplications of the brake button does this nicely for me) as soon as i see the opposition roll into stage i floor it. my 512 hard on the limiter is enough for the starter to drop his thumb & i'm gone. my opposition barely has time to get on the limiter before the orange lights are on so i've usually holeshot them. my button only requires 0.020 movement to release & my brake(A&A Ultimate brake) don't need any rpm to set so i can lock in the brake on idle. a few months back we had a thread on here about locking in brakes & some racers have to rev the engine to get the brake to lock. for the life of me i can't understand how you can win a race having to do that. must be all about line press. anyway thats my startline stratagy, works for me most times.
Re: Pro Tree- How do you deal with it? #476476
09/23/09 09:25 AM
09/23/09 09:25 AM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
I like the sound of that. It needs to be more instinct than a command from the brain. I just came back from the garage, and looking at all the timeslips, there were a couple .150, a .250,.285 and a couple .500ish. What is considered a good pro-tree light considering one waits to see yellow?
Post deleted by Defbob [Re: dartman366] #476477
09/23/09 09:32 AM
09/23/09 09:32 AM
Re: Pro Tree- How do you deal with it? #476478
09/23/09 04:34 PM
09/23/09 04:34 PM
That's what I was trying to get across. You can not wait for the light hitting your eye to filter through the whole chain of command.
Some guy's might have a faster hand eye connection than me, but once I got my brain & muscles bypassed, I got .08-.09 quicker on a pro tree.
This from a guy that would red light a bunch of a full tree, leaving on the flash of the bottom bulb.
If you don't know what a good light is, I would suggest you look at a national dragster sportsman edition.
Those guys are frigging amazing. When I tried to run S/G I always got the .408, .406 guys next to me.
I never had a chance with my small tire tank.
