Paint Removal? #476364
09/22/09 03:35 AM
09/22/09 03:35 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Best method of Paint removal for an A Body? I am talking inside and out.
Media Blasting?
Acid Dipping?
Pro's and Con's of the method you used?
Thanks in Advance
AL....
Alan Jones
Re: Paint Removal? [Re: LA360] #476365
09/22/09 09:09 AM
09/22/09 09:09 AM
Jacksonville Florida
elitecustombody Offline
media blasting is better than acid dip,there are way too many horror stories after acid dip,few years later,the acid that wasn't completely washed out started some serious corrosion in tight areas,
There are alot of people who have soda blasted their cars,but if the metal is not treated right ,you may have alot of peeling issues,so if you choose to go that route,make sure the metal is neutralized before epoxy or any bodywork
I'd media blast
Re: Paint Removal? [Re: LA360] #476366
09/22/09 09:54 AM
09/22/09 09:54 AM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
media blast because it's shot at the car so anything it takes off you can put back on with a spray gun. dipping will remove the paint from anyplace 2 panels come together like the deck lid ( trunk ) but how will you put it back on. In my opinion your asking for a rust problem. The media is hard to get out of the car but if you take your time and use an air blow gun and a good shopvac get as much as you can out when it comes home. Start doing bodywork your DA will vibrate alot of the media out then every other day push it outside blow the bodywork dust off and blow and suck every hole, crack and crevice ( takes about an hour)after about a week of this you will be media free. you will have the same problem with soda blast yes the soda will dissolve with water but the paint rust and crap that came off the car doesn't and I don't think anybody has come up with a solution for making paint stay on soda blasted metal. Here is a link http://www.facebook.com/album.php?aid=6165&id=100000065054491&l=cde96ca26e to some pics of my car it was media blasted January 18th of this year and it's been done about 2 months now.
