Refresh my memory on squirter size with 50cc pumps. #476200
09/21/09 10:12 PM
09/21/09 10:12 PM
Missouri
StrokerPost Offline OP
Missouri
I seem to remember someone saying that if you switch to a 50cc pump from a 30cc that you would want to use a smaller squirter than you used with the 30cc pump, is that correct? If so, using an 850 DP as an example, if you were chaging out the rear pump with a 50cc where might you want to start on squirter size? Thanks for any input.
Ken.
Re: Refresh my memory on squirter size with 50cc pumps. [Re: StrokerPost] #476201
09/21/09 11:35 PM
09/21/09 11:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
I don't like 50 CC pumps I wouldn't change the suirters until you run it at the track to see some 60 ft times. I like to run the smallest squirters I can (with no bog)to keep the motor crisp from starting line to the finish line
Re: Refresh my memory on squirter size with 50cc pumps. [Re: StrokerPost] #476202
09/22/09 07:30 PM
09/22/09 07:30 PM
Missouri
Missouri
Thanks Cab. Any new thoughts on this a new day?
Re: Refresh my memory on squirter size with 50cc pumps. [Re: StrokerPost] #476203
09/22/09 07:53 PM
09/22/09 07:53 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
well assuming you need the 50ccs cuz you don't have enough pump shot, no you want a bigger squirter. I've certainly never changed to a 50 and DECREASED the squirter size, that's lunacy.
I typically use anywhere from 35 up into the 40's. I guess some monster dominators might need bigger.
Re: Refresh my memory on squirter size with 50cc pumps. [Re: CokeBottleKid] #476204
09/22/09 07:58 PM
09/22/09 07:58 PM
Q
Quicktree Offline
Quicktree  Offline
Q
50cc pumps makes tunning so much easier imo. on a smaller carb 750-850 28-31 squirters should be in the ball park.
