12 volt coil, bypass ballast resistor? #476028
09/21/09 08:21 PM
09/21/09 08:21 PM
timinator Offline OP
I installed a 12 volt Accel coil on my 440 Charger. I know the stock system runs 12 volts to the coil for starting, then 6 volts for normal running. My friend said with this coil, I should be running a constant 12 volts at all times. Is this correct and if so, how do I wire this up? Do I just connect the two leads that go through the ballast resistor and bypass it? It also has the MP electronic ignition conversion if this matters.
Re: 12 volt coil, bypass ballast resistor? [Re: timinator] #476029
09/21/09 08:37 PM
09/21/09 08:37 PM
MNobody Offline
MNobody  Offline
I don't think it's recommended if your still running the stock ECU.
Re: 12 volt coil, bypass ballast resistor? [Re: MNobody] #476030
09/21/09 10:10 PM
09/21/09 10:10 PM
which Accel coil?. Yes connecting the 2 leads on the BR will bypass it but most coils require a BR of some particular resistance.
Re: 12 volt coil, bypass ballast resistor? [Re: RapidRobert] #476031
09/21/09 10:53 PM
09/21/09 10:53 PM
IA
landon1 Offline
landon1  Offline
IA
i run an accel 12 volt coil, but i have an HEI/bosch type distributor that can run off 12 volts without burning up - to bypass, you would just connect the wires together - that's how i had mine hooked-up.
'71 Satellite Sebring 440
Re: 12 volt coil, bypass ballast resistor? [Re: landon1] #476032
09/22/09 12:43 AM
09/22/09 12:43 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I bought an accel coil and ran my stock 70's electronic ignition ballast and burned it up pretty quick. The way I heard it is the ballast is needed unless you have an aftermarket current-limiting ignition system, ie msd, r2r distributors, etc. It's not the voltage that's the issue, it's the current thru the coil terminals.
Re: 12 volt coil, bypass ballast resistor? [Re: DaytonaTurbo] #476033
09/22/09 11:47 AM
09/22/09 11:47 AM
It's the Accel Super Stock 12V universal performance coil (part# 8140). So, shouldn't it be getting 12 volts instead of 6? Again, it's the MP electronic ignition conversion so I don't know if this limits current. I had the same coil on it and it burned out which is why I replaced it. It only had a couple hundred miles on it. Is too low of voltage going to burn it out?
Re: 12 volt coil, bypass ballast resistor? [Re: timinator] #476034
09/22/09 03:42 PM
09/22/09 03:42 PM
no, only more voltage than the coils' designed for will kill it after enough time. Less will give you inadequate spark (& potentially a miss) especially under load.
Re: 12 volt coil, bypass ballast resistor? [Re: RapidRobert] #476035
09/22/09 04:16 PM
09/22/09 04:16 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I've never used a ballast resistor with an MP distributor and a good aftermarket coil. Never had a problem.
Re: 12 volt coil, bypass ballast resistor? [Re: timinator] #476036
09/22/09 04:35 PM
09/22/09 04:35 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
This one says for Mopar
I was thinking about buying this one. I wonder if it's supposed to use the ballast?
Moparlee
Re: 12 volt coil, bypass ballast resistor? [Re: Robbins] #476037
09/22/09 05:48 PM
09/22/09 05:48 PM
I contacted tech support at Accel about the 8140M which is supposed to be for Mopar. Still waiting to hear back.
Re: 12 volt coil, bypass ballast resistor? [Re: timinator] #476038
09/22/09 06:29 PM
09/22/09 06:29 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I did also by the website, but the last time I tried that I never got anything back. I did call them on the 59300 dizzy and found out it was a billet style. So I'm going to probably run that coil if it used the ballast.
Moparlee
Re: 12 volt coil, bypass ballast resistor? [Re: Robbins] #476039
09/23/09 08:24 AM
09/23/09 08:24 AM
Valrico FL
1toolguy Offline
1toolguy  Offline
Valrico FL
I don't remember the letter designation but the standard "universal" 8140 will give you fits! I know becasue we chased a problem for about a month. The universal 8140 will overheat your ignition module causing it to slowly limit your RPMs (the worst day we had was 1500!)
Re: 12 volt coil, bypass ballast resistor? [Re: 1toolguy] #476040
09/24/09 07:26 PM
09/24/09 07:26 PM
Pacific NW
cuda66318 Offline
cuda66318  Offline
Pacific NW
I've run the 8410 on our load bank, just thru it in the trash can not even close to a quality piece....note the label made in ???? come on Guess for me.
Just to answer your question it's designed to run at 6V through the ballast any more than that it will overheat and drop voltage, the 8410 is a points coil and not recommended for Electronic.
get the right stuff and quit wasting you money on all this witches brew http://www.4secondsflat.com/Ignition.html
Re: 12 volt coil, bypass ballast resistor? [Re: cuda66318] #476041
10/01/09 10:41 PM
10/01/09 10:41 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I just put mine on tonight. So far so good. It's the 8140M (mopar) one. If it makes a difference or not. I'll post if it goes down hill from here.
Moparlee
Re: 12 volt coil, bypass ballast resistor? [Re: Robbins] #476042
10/02/09 04:35 PM
10/02/09 04:35 PM
Dougsmopars Offline
Dougsmopars  Offline
The old Accel coils were good. But now all imports. Lot of people having problems. I use an MSD Blaster coil. MP electronic dizzy with orange box. Blue HP mopar voltage regulator no ballast resistor. Never had a problem. Same set up on my Road Runner 4 years. Never skipped a beat.
Re: 12 volt coil, bypass ballast resistor? [Re: Dougsmopars] #476043
10/02/09 10:24 PM
10/02/09 10:24 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I'm hoping that I won't have a problem....it's made in china so we'll see. If it don't work I definitely post so more people will see what they are (Accel) is selling these days.
By the way when I was on the phone with them(Accel) they basically was saying that they build Mopar Performance's distributers for them.
Moparlee
Re: 12 volt coil, bypass ballast resistor? [Re: Robbins] #476044
10/02/09 10:25 PM
10/02/09 10:25 PM
Dougsmopars Offline
Dougsmopars  Offline
Even the MSD coil is imported. Nothing is made here anymore.
Re: 12 volt coil, bypass ballast resistor? [Re: Dougsmopars] #476045
10/02/09 10:29 PM
10/02/09 10:29 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
That doesn't surprise me. I have a Mopar Performance blaster two and 6al(MSD stuff all in black). It works flawlessly.
I'll be getting the Accel billet(ACC-59300) dizzy here in the next week or so. I'm hoping it's going to be worth a poop.
Moparlee
