Page 6 of 7 1 2 3 4 5 6 7
Re: Issues with repop E body brake cables..... [Re: HPMike] #475986
10/18/09 07:55 PM
10/18/09 07:55 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
This is a picture of the Inline Tube clip and an original one, sorry it ain't pretty.
It looks like the clip goes in the hole before the cable?
Re: Issues with repop E body brake cables..... [Re: Snoopy] #475987
10/18/09 08:04 PM
10/18/09 08:04 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Snoopy,
Thank you!
Re: Issues with repop E body brake cables..... [Re: Snoopy] #475988
10/18/09 08:52 PM
10/18/09 08:52 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
That would be correct.
Re: Issues with repop E body brake cables..... [Re: 62maxwgn] #475989
10/19/09 06:30 PM
10/19/09 06:30 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Thanks Bill!
Re: Issues with repop E body brake cables..... #475990
10/21/09 03:51 PM
10/21/09 03:51 PM
Snoopy Offline
Snoopy  Offline
Marc McGrew at Inline Tube was kind enough to send me a new grommet for my front emergency brake cable.
Marc, thank you.
Here is a comparison picture showing the differences between Inline's grommet and a used original.
Re: Issues with repop E body brake cables..... [Re: Snoopy] #475991
10/21/09 04:22 PM
10/21/09 04:22 PM
Snoopy Offline
Snoopy  Offline
Now for the next challenge. Shoving a 3/4" diameter part through a 11/32" diameter hole.
Re: Issues with repop E body brake cables..... [Re: Snoopy] #475992
10/21/09 04:28 PM
10/21/09 04:28 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Marc, thank you.
When I get to the office tomorrow I will try to post a picture of the one we did for Fine Lines that I'm test fitting right now. It looks identical to your original Snoopy except I didn't machine the "FB" in the tool yet.
Re: Issues with repop E body brake cables..... [Re: Snoopy] #475993
10/21/09 05:21 PM
10/21/09 05:21 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Soak the grommet in hot water for a while and then apply some lube... Really helps.
Re: Issues with repop E body brake cables..... [Re: Snoopy] #475994
10/21/09 06:01 PM
10/21/09 06:01 PM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
Use liquid hand soap and it will go right on.
MB
Re: Issues with repop E body brake cables..... [Re: HPMike] #475995
10/21/09 07:06 PM
10/21/09 07:06 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
WOW
this thread is loaded with great info. i've been crying about my repo e-brake junk for 4 years now. glad to see people speaking out
Re: Issues with repop E body brake cables..... [Re: Snoopy] #475996
10/21/09 10:30 PM
10/21/09 10:30 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Here is one of a couple we pounded out for testing.
Re: Issues with repop E body brake cables..... [Re: HEMICUDA] #475997
10/21/09 10:32 PM
10/21/09 10:32 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Back side. I would be more than happy to supply these to Inline if they're interested so they will have the right grommet for their cable sets.
Re: Issues with repop E body brake cables..... [Re: HPMike] #475998
10/25/09 03:31 PM
10/25/09 03:31 PM
New Jersey
FC7 cuda Offline
FC7 cuda  Offline
New Jersey
where do you get the proper clips ??? mine all broke
Re: Issues with repop E body brake cables..... [Re: joelson6] #475999
10/26/09 01:22 PM
10/26/09 01:22 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i thought i was the only one that was having issues with my e-brake stuff. not only is the lengths different, did anyone find the ball on the ends of the intermediate cable to be larger than original? i brought one to Ohio 2 years ago and showed someone from inline tube the difference with my cable and a repo. i got the "DUH, are you sure it's original, DUH. um, oh, um uuhhh". then i asked why they don't make them like the originals, i got "uh, oh, uumm, i don't know, duh".
one thing i've learned from restoring my Challenger
repo, junk
repo, junk
repo, junk
every repo part i've put on my car, i had to modify in some way shape or form
repo, junk
yes, I posted that and was told to grind out the holes to make them fit. but ya, the balls are bigger
Re: Issues with repop E body brake cables..... [Re: bremotorsports] #476000
05/12/10 02:28 PM
05/12/10 02:28 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Re: Issues with repop E body brake cables..... [Re: aarcuda] #476001
05/12/10 03:38 PM
05/12/10 03:38 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
yea aarcuda, that's what i did.
it's a shame that someone can't just buy a piece or couple of pieces to replace damaged or missing parts. you need to buy everything to make it work the way the reproduction was designed. OR modify parts to get it to work correctly.
the intermediate cable i bought didn't have the plate that the adjuster rod goes through. i had to pry my old one off and put it on the int. cable.
the ball ends were bigger, so i had to drill out the clips that attach the back cable to the int. cable.
and finally, because the cable was longer, i didn't think it was gonna fit. BUT i was able to put the adjuster rod in a different hole in the frame to make it work.
it works fine, but i guess i'm gonna lose points because of that
Re: Issues with repop E body brake cables..... [Re: HPMike] #476002
12/15/13 03:52 AM
12/15/13 03:52 AM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
I realize this is an old thread, but I wanted to refresh the questions/issues, as I am in need of a kit for my '70 Challenger (w/o intermediate cable). What have been your recent experiences with Inline Tubes and/or Fine Lines for their E-brake cable kits (specifically regarding cable length accuracy, quality of manufacturing, and customer service satisfaction)? Any other recommendations for vendors/manufactures? I only want to do this once w/o the nightmares I've read about from other member's past experiences. Thanks.
Re: Issues with repop E body brake cables..... [Re: filmsurgeon] #476003
12/15/13 03:48 PM
12/15/13 03:48 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Wow: Good thread, I'm heading out to the garage to clean up the original cables it looks like.
Sheldon
Re: Issues with repop E body brake cables..... [Re: gomangoRTSE] #476004
12/16/13 01:49 PM
12/16/13 01:49 PM
pa.
dan9 Offline
dan9  Offline
pa.
I got a set from Summit Racing (Right Stuff) for my 70 Challenger. Mine fit perfectly.
Re: Issues with repop E body brake cables..... [Re: dan9] #476005
12/17/13 04:50 AM
12/17/13 04:50 AM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
Thanks. I know about the "Right Stuff" product. I understand they are good "aftermarket" cables, but I'm looking toward either Fine Lines or Inline Tubes for their "factory correct" manufacturing.
