Re: Issues with repop E body brake cables.....
[Re: gtx6970]
#475966
10/12/09 07:18 PM
10/12/09 07:18 PM
WRONG they don,t fit because those are brake HOSE clips not brake CABLE clips
left is cabe clip right is hose clip
#475967
10/12/09 07:29 PM
10/12/09 07:29 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
That's what i was thinking.....
Now, I am not sure if Tomr's clip is different from the ones I have experience with, but they kinda look the same as the ones pictured on the left. Do you notice the circular outline on the inside of the clip? Well that part winds up coming away from the clip and they now become pretty much useless as they don't securely hold the cable to the frame bracket. And they are rather flimsy and lack the rigidity and tension of the originals. Hopefully I have explained it so all can understand. If someone wants to add anything to clarify, feel free to do so. Again, bear in mind that while they kinda look the same, Tom may have a superior item than what I have had sent with the cables I have used.
MB
#475968
10/12/09 09:25 PM
10/12/09 09:25 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
I've used the clips that were supplied with the cables by Inline Tube only to find them lying on the floor with the centers broken out. I'm not using brake hose clips. Trust me, I've assembly a few E bodys this year alone.... ![](/ubbthreads/images/graemlins/Twocents.gif)
CHECK OUT MY NEW WEB SITE !
[Re: burdar]
#475973
10/16/09 07:23 PM
10/16/09 07:23 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
Inline Tube is aware that the ball ends on our parking brake cables are larger than the factory ball. This was done for saftey reasons after having several small ball failures on original cables because of the small surface area. Also all of Inline Tube's hardware is designed to work with the larger ball which is only 1/16 larger in diameter then the original. This small ball end is only on 1 of the 3 to 4 cables and does not affect any function and is not even visable because once it is installed in the hardware you can not see the end of the cable.
Do the Fine Lines cables use the original ball size?
[Re: Snoopy]
#475975
10/17/09 04:13 PM
10/17/09 04:13 PM
Snoopy
Maybe it's just me, but the difference in diameter looks like a lot more than 1/16" Inline Tube Ball = 0.443" Original Ball = 0.312"
[Re: Snoopy]
#475981
10/18/09 02:51 PM
10/18/09 02:51 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
What are these clips?
M/T clutch linkage clips.
