Page 5 of 18 1 2 3 4 5 6 7 17 18
Re: Super duper gas miledge 273 experiment !!! [Re: Clair_Davis] #47587
11/28/07 09:12 AM
11/28/07 09:12 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
We'll need to keep this thread rolling as Dave is moving to Montana today. Unless plans have changed.
I think he's going to raise himself up a crop of dental floss..........
Safe trip Dave and family!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Super duper gas miledge 273 experiment !!! [Re: Rug_Trucker] #47588
11/28/07 12:35 PM
11/28/07 12:35 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
another thing to consider, I've read the closer the valve is to the cylinder side, the more swirl is induced from that shrouding. on a 273, anything larger than the stock 1.78/1.5 valves require bore notching to avoid a collision between the valve and cylinder bore, so the shrouding effects will probably be about the same regardless of head/valve size. on a 318's 3.91" bore, the magnum's 1.92/1.625" valves may give them an additional boost in induced swirl over a 273 head or '302 head with the small 1.78/1.5 valves...
I'm still not convinced the 273 will give any significant mileage improvement over a similarly built 318. for cost and ease of parts aquisition, I still think a 318 (roller cam block) is the way to go, especially if trying to optimize power and economy.
2017 Grand Cherokee Overland
Re: Super duper gas miledge 273 experiment !!! [Re: patrick] #47589
11/28/07 01:09 PM
11/28/07 01:09 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
What 273 heads does he have? Open chamber 67-69's or the earlier closed chamber models with the funky bolts?
If it's the open chamber, I certainly go with the 302's just for the sake of squeezing a better CR out of the thing with minimal hassle.
I would think as far as rear end ratio goes, you would want to choose it (and your tire size) so that your target cruise rpm equals your peak torque rpm, eh?
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Super duper gas miledge 273 experiment !!! [Re: dart4forte] #47590
11/28/07 01:54 PM
11/28/07 01:54 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
The 273 heads will have less velocity because they have a slightly larger port volume. Not that they would be a bad choice for that reason, they would make less pumping losses. That is also a reason for me to consider the magnums, I have a set of them and the 273 heads but no 302s...
I called my buddy that owns the flow bench. He recalls the velocity was greater on the 273 head vs the swirl port. He's going to pull it up on the computer and I'll post the numbers. Also remember that with the magnums you'll need the corresponding valve train and intake in order for the heads to work. There will be a lot of port mismatch with a Magnum/273.
Here are the numbers off my head. i tried to scan the test data but it wouldn't show in color and was impossible to read. I'll try and explain what is depicted on the sheet.
Used a 302 Swirl port vs the stock 273.
both had the same modifacations except we stayed with the stock intake size on the 302 and only modified with a stainless valve.
The 273 used a cut 1.88 stainless valve down to 1.84. We found this size ideal for the 273 to prevent shrouding.
First test
273 with a 1.84 intake, 1.56 exhaust with alittle bowl work Same on the 302 except larger intake and exhaust valve.
113% max velocity on both heads
2nd test
273 head with same mod with the addition of more port work, 70 degree bowl cut and 3 angle valve job. 302 the same, both had Ferra valves
Gained 116% on the 273 and 115% on the 302
1st test
The flow numbers showed a big differance with the 273 showing max flow of 166.9 cfm at .400 of lift with the flow curve remaining steading and not falling off until .475 of lift.
The 302 however showed a max of 161.8 and started to fall off at around .500 lift
2nd test
273 showed 169 cfm at .450 lift where the 302 showed 163 cfm at .450 then dropping off.
273 and 302 had the same modifacations.
Re: Super duper gas miledge 273 experiment !!! [Re: dart4forte] #47591
11/28/07 04:51 PM
11/28/07 04:51 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
First test
2nd test
1st test
2nd test
what bore was that tested on, a 273 bore, or a 318 bore, or a 4" (360) bore?
Re: Super duper gas miledge 273 experiment !!! [Re: patrick] #47592
11/28/07 04:56 PM
11/28/07 04:56 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Not sure on your question. are you referring to the plastic plate the head is bolted to? if so it wouldn't make a differance since it's a measurement of the head in and out.
Re: Super duper gas miledge 273 experiment !!! [Re: dart4forte] #47593
11/29/07 09:17 AM
11/29/07 09:17 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
when heads are flowed on a flow bench, they're allways bolted down to a bore plate simulating the cylinder sidewall, and yes, it will make a difference in flow, as the valve gets closer to the cylinder wall, it will be shrouded more, and recorded flow will drop. IIRC Ryan J did a flow test of a set of heads on like a 4.25" bore plate and the same heads on a 4" bore plate, and he saw over a 10% decrease in flow between the tests, IIRC.
Re: Super duper gas miledge 273 experiment !!! [Re: Clair_Davis] #47594
11/29/07 09:36 AM
11/29/07 09:36 AM
central IL
myduster360 Offline
myduster360  Offline
central IL
At what point does good swirl/tumble/mix become more important than just velocity? If we're talking a couple % faster in a 44-year old head vs. a 24-year old head, I choose the newer one every time.
Clair
Absolute Velocity(cfm) is a very small factor when attempting to judge combustion efficiency.
I did some cylinder head development with Cummins in college and they actually measure "SWIRL TORQUE" in the cylinder to judge comb eff. This quantifies exactly how fast the air is swirling around once in the cylinder. An increase "swirl torque" had a significant impact on comb eff, but was somewhat independent of absolute port velocity ei: more HP, more mass air flow and less HC emissions from the same CFM.
In the last 20years steady state CFM has become an increasingly less significant design aspect of new OEM cylinder heads.
Bottom line: When in doubt always go with the newer designed head.
1972 Swinger 3.6L Pentastar
Diablo CMR tuner
Re: Super duper gas miledge 273 experiment !!! [Re: patrick] #47595
11/29/07 03:54 PM
11/29/07 03:54 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
I think he was just pointing out that with the same valve size b/w the 273 heads and 318 #302 heads, even if the flow is affected (which it is), it would affect both heads the same, so the comparison is valid.
However, I agree, anytime flow is tested, I like to know the bore size
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Super duper gas miledge 273 experiment !!! [Re: Prince_Valiant] #47596
11/29/07 05:17 PM
11/29/07 05:17 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I'll have to ask. He stopped by yesterday with the printout. Since I was there when he did the test I do know he used the same bore plate. Just for information the heads I put on the 273 had a bit more work than the heads he used for the comparrison test. My heads had a 70 degree bowl cut with a lot of blending and removing any sharp edges, removed sharp edges on int. and exh ports. Did a short turn radius cut around valve guides and a 30,45,60,70 degree cut on the intake valve (1.84) and a 15,45,60,79 on the exh. Used Ferra valves. Got 116% max velocity and they flowed 169.1 cfm at .500 of lift.
Re: Super duper gas miledge 273 experiment !!! [Re: dart4forte] #47597
11/29/07 05:28 PM
11/29/07 05:28 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
This is an interesting thread. I have 273 heads on a 318 Duster. Has identical mods as yours and I ran a 15.9 (at 5000ft) with it. My next project is a 318 Volare that I'm going to put 273 heads on. I'm going to use the 2 barrel single plane intake that goes with the 273 heads and see what kind of mileage I can sqeeze out of it. I just like those 273 heads! They are lighter too and they don't seem to crack or warp like the 302's
Re: Super duper gas miledge 273 experiment !!! [Re: dmerc] #47598
11/29/07 08:22 PM
11/29/07 08:22 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have a good friend and engine builder that is a class racer. He raced a 273 car years back and now races a 340 Duster. One can actually make the 273 scream. there's a Stock Eliminator racer by the name of Wong that races 273 cars and gets them into low numbers.
Re: Super duper gas miledge 273 experiment !!! [Re: patrick] #47599
11/29/07 10:21 PM
11/29/07 10:21 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
First test
2nd test
1st test
2nd test
Got an answer for you. They were tested on a 4" bore plate
Re: Super duper gas miledge 273 experiment !!! [Re: Rug_Trucker] #47600
11/30/07 12:04 AM
11/30/07 12:04 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I hope he saves the wax...
BTW, I hate to ask a pretty basic question this late in the thread, but what exactly is this "115% max velocity" stuff referring to? I guess I haven't seen this terminology before...
Clair
Re: Super duper gas miledge 273 experiment !!! [Re: Clair_Davis] #47601
12/05/07 08:47 AM
12/05/07 08:47 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
for a
"SuperDuper MPG experiment"
wouldn't the octane tolerance of a cylinder head and piston crown combination be more important than any swirl numbers?
I know swirl can improve fast burn,
and fast burn can improve octane tolerance,
but the stuff I have seen
says that 'old fashioned' quench area works better
but that modern cylinder heads have had to cut
back on quench area due to pollution concerns related to NOx
Porsche engineer May's HE "Fireball" high quench area head for Jaguar's V12:
http://www.jagweb.com/jagworld/v12-engine/page3.html
Larry Widmer's 'Soft Head' article (aka TOO or "The Old One")
http://www.theoldone.com/articles/The_Soft_Head_1999/
the Aussie view of pinging & detonation:
http://autospeed.com/cms/A_0601/article.html
Re: Super duper gas miledge 273 experiment !!! UPDATE [Re: HotRodDave] #47602
01/01/08 11:10 PM
01/01/08 11:10 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Well I picked up a 318 block today and was going to have it zero decked and use some 68 style stock pistons and 340 rods. I carried it all to the machine shop to mill a bunch off the deck and the guy gave me a really good super dooper screaming deal on a set of KB 167 pistons .030 over so I will be useing this short block with the SCAT I beams from my busted stroker. The pistons are 100g lighter a piece and the rods were 115g lighter each, also I should lose even more weight from balancing it and make a very light rotateing assy. It should be easy enough for every one to copy also.
For the top end I am going to put on some 302 heads, I have not decided if I am going to put in some 1.88 valves I have around here but there won't be much porting going on. Mabey put on a groove in the chambers for good measure
For a cam I have a 273 2bbl solid cam lifters and rockers I will use.
I have an LD4B or Holley street dominator to pick from. I am still hopeing to find a offy dual port
I will run a small Thermo-quad and my car already has TTI headers so soon I should have this thing goin. I will probably drive it like this for a little bit before I put in an OD trans. It has 2.76 gears right now.
Any one want to venture what improvement just the motor will give me from my stock 68 318 2bbl?
Re: Super duper gas miledge 273 experiment !!! UPDATE [Re: HotRodDave] #47603
01/01/08 11:25 PM
01/01/08 11:25 PM
near Alexandria, VA
Gas_Bandit Offline
Gas_Bandit  Offline
near Alexandria, VA
I don't think a lighter rotating assembly is going to save you any noticeable mpg. Acceleration will be better, but cruising, you are already spinning the rotating assembly. It sounds like you are building more or less how the 318s came from the factory in the 80s, w/ a tiny solid cam.
2003 Mercury Marauder, 34k miles, 3.73s and custom flash tuned
1981 Camaro, 350 w/ Holley Stealth Ram MPEFI, Sportsman heads, roller cam, self-burned chips, wideband O2
1983 Firebird TA
1993 Saturn SL2 83k
Re: Super duper gas miledge 273 experiment !!! UPDATE [Re: Gas_Bandit] #47604
01/02/08 01:22 AM
01/02/08 01:22 AM
Kalispell Mt.
Kalispell Mt.
The problem those cars had with intown miledge was gettin everything moveing, they got good miledge on the highway. The light weight stuff should help a bunch in town. I will be removeing at least 1600 grams from the rotateing assy plus removeing weight from the crank to balance it roughly 1200 more grams for a total of 2800 grams Now consider that weight in first gear has to accelerate 7.5 times as fast as the car it will be like removeing 21,000 grams from the vehicle, or almost 50 lbs everytime the engine speeds up or down. I also remember reading the weight actually goes up exponetialy not lineraly so it would rev even easier. And also my car is already 500lbs lighter than those dippys and 5th aves.
Compresion will be at least 1.5 higher ratio and should be good by itself for %4 more power from the same fuel or %4 more miledge. Also the tighter quench will cause a lot more turbulence resulting in a faster and more complete burn so I can run less advance to get les negative work on the piston before TDC. Even if the headers don't hit there tuned RPM the engine will do less work forcing the gasses through them than the 3 cats and very restrictive single exhaust the mid 80s cars had. I will have no EGR valve to slow the part throttle burn rate either.
The cam is a couple degrees smaller so a tad less overlap and solids have slightly less friction than a hydro mabey a tad more than a roller but I can tune the valve lash for a little more efficency.
If I can find a dual port intake it should also help build mixture velocity at low speeds around town.
I can run it a little leaner (14.7 is the goal)without worying about burning up the cats or NOx emmisions.
I am expecting to beat my current best MPG by at least 5 mpg while I am really hopeing for 10mpg better. My current best ever was 23mpg mostly highway driving. Strictly in town I would usually get 17mpg.
I think it should be a drastic improvement from the 80s
Re: Super duper gas miledge 273 experiment !!! UPDATE [Re: HotRodDave] #47605
01/02/08 07:43 AM
01/02/08 07:43 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I was getting 22mpg with my closed chamber 273 heads on a 318 and running a RV cam. It will be real interesting to see what you end up with. My engine was non quench with a 500 cfm carter carb and 2.92 gears, also lock up trany. I run at 5000 ft. Assuming the correct jetting I wonder what the effect of altitude is on gas mileage? Looking forward to your results
Re: Super duper gas miledge 273/318 experiment !!! UPDATE [Re: HotRodDave] #47606
01/25/08 01:36 AM
01/25/08 01:36 AM
Kalispell Mt.
Kalispell Mt.
Fired it up today!!!
Here is what I have
68 318 block .030 over
KB 167 pistons .005 down
.039 felpros
Scat I beam rods
Balanced rotateing assy (very light)
273 2bbl solid cam, lifters and rockers
full grooved mains
302 casting heads with all sharp spots smoothed down
LD4b intake
850 thermo-quad
904 LU with low 1st and 2nd
2.76 gears
No PS No AC
Electric fan
TTI step headers
10 degrees at idle and 30 total and no vacume advance yet, I don't want it detonateing when I can't here it because of the exhaust.
and that is where it ends, no exhaust after the hearers. It revs real quick but it is sounding lean over 3500 rpm with a bunch of bucking and coughing. It hesitates if you hit it too hard also. I will try doing some carb tuneing tommorow. I may try to get an exhaust on it first though.
What size pipes should I run on this thing, any thoughts???
Any other sugestions???
