Re: What size wheel for a stock suspension Duster?
[Re: Jeepmon]
#475428
09/21/09 04:15 PM
09/21/09 04:15 PM
Posts: 5,894 Florida
Locomotion
Most Stock class racers use a 10" wheel with 9" slicks with a stock spring location. But its's all very close and you have to watch backspacing as well as varying tire section widths of each tire you consider because they can vary despite a common tread width. I have 10" Holeshot Wheels with 9" Hoosier slicks on my car, but also have the springs moved in 3/4" because IHRA allows it. Offset to the inside appears to be 4 7/8". From the mounting surface to the inner rim lip. Not sure if you might have to consider 3 7/8" with springs in the stock location. Holeshot normally makes wheels in 1" increment offsets (i.e.: 3 7/8", 4 7/8", 5 7/8", etc.) But they can fine-tune those measurements, if those might be an option. Holeshot Wheels web site. Photo showing my rear wheel/tire-to-body relationship.
[Re: Locomotion]
#475429
09/21/09 04:50 PM
09/21/09 04:50 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
I don't think you can get anything more than a 9 inch tire in there, you can only get 8.5 in a dart
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 65signet]
#475430
09/21/09 04:57 PM
09/21/09 04:57 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
I have a stock suspension Duster, i have been able to fit 10 inch wheels with 5.5 bs and 28 by 11.5 QTP tires(true 10 inch wide)...you need wheel spacers to do this.. i had my dana made .5 of an inch wider per side to get rid of the spacers i used with my 8.75 rear.It will work like i currently have it with wheel spacers..going from 8 inch to 10 inch wheels made a huge dfferece on my high 9 sec car....
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
