330' Time.... #474287
09/21/09 12:53 AM
09/21/09 12:53 AM
PORT ALBERNI , BC., CANADA
superwrench Offline OP
The small track up here in Victoria is only 400' long, so all you get is a 60' and a 330' time to go by.
On one run today, my Pink Pig laid down a 1.51 60' and a 4.392 330'.
What does that 330' time equate to as an approximate 1/4 time? I'm thinking in the 10.80 range.
Re: 330' Time.... [Re: superwrench] #474288
09/21/09 01:37 AM
09/21/09 01:37 AM
Renton Washington
Triple Threat Offline
Renton Washington
All cars are a little different, the Easiest and most accurate way to figure it out is to compare it to your timeslips from a 1/4 mile track, like the info you got from pinks here at pacific.
-Dustin
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 330' Time.... [Re: Triple Threat] #474289
09/21/09 02:16 AM
09/21/09 02:16 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Re: 330' Time.... [Re: RobX4406] #474290
09/21/09 10:13 AM
09/21/09 10:13 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Now that is a good piece of info to have. It'll get you in the ball park of were you should be. Now that I find I'm .3 off in my et per 60 ft. vs mph , it's back to work
