2009 Engine masters dyno #s #474042
09/20/09 09:17 PM
09/20/09 09:17 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Got the engine masters engine on the dyno.....
I had some issues on the dyno that ate up some testing time but we did find 40 HP in jetting and timing that was good but with the set back it got me off my game plan of tests I would like to run.
I would have loved to move cam around some but that did not help last year at all So we slamed 6 sets of headers on and off it LOL found some odd stuff like 3" collector made more top end HP and less TQ than 3.5" collector....
engine is 394 CI
10.9to1 CR Indy heads (Not out of the box)
https://board.moparts.org/ubbthreads/show...part=1&vc=1
link to some of the build.
Re: 2009 Engine masters dyno #s [Re: W5DART66] #474043
09/20/09 09:47 PM
09/20/09 09:47 PM
south louisiana
lowell66dart Offline
south louisiana
Cool. Good luck with the contest.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: 2009 Engine masters dyno #s [Re: lowell66dart] #474044
09/20/09 09:52 PM
09/20/09 09:52 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I was sitting with Vic when you called the other night.I was pretty impressed with the gains you acheived in such a short time.
Lookin' good!
Re: 2009 Engine masters dyno #s [Re: W5DART66] #474045
09/20/09 09:54 PM
09/20/09 09:54 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Awesome, Brett. Good luck.
Re: 2009 Engine masters dyno #s [Re: Leigh] #474046
09/20/09 11:14 PM
09/20/09 11:14 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
it stays above 500 ftlb for quite a bit..
looks pretty impressive..
surprised on the stroke..was that
just due to parts available?
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 2009 Engine masters dyno #s [Re: W5DART66] #474047
09/21/09 12:03 AM
09/21/09 12:03 AM
Do you know where the motor makes peak HP yet? It looks like it is still climbing at the RPM you stop on the dyno sheet I have seen a short( less than four inch) stroke motor almost stop making HP increase at 6500 rpm and then take another breath 400 rpm later and make peak power at 7800 RPM and gain almost 50 HP
Re: 2009 Engine masters dyno #s [Re: Cab_Burge] #474048
09/21/09 12:22 AM
09/21/09 12:22 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
In the engine masters competition they are only going to pull to 7000 RPM so no sense worrying about hp past there. However, I do think it could be benifitial to know if it made more HP higher up, then you would know your cam and induction were a little too big and could stand to be shrunk to help your low RPM power and get a better average in the challenges RPM range
Re: 2009 Engine masters dyno #s [Re: HotRodDave] #474049
09/21/09 06:49 AM
09/21/09 06:49 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Yes I am off on the cam it makes peek power at 7300 rpm 662 peek HP that is why I wish I would have advanced the cam more(its ground on 108 in at 102 right now)
Re: 2009 Engine masters dyno #s [Re: W5DART66] #474050
09/21/09 08:06 AM
09/21/09 08:06 AM
The Great White North
RAMM Offline
RAMM  Offline
What intake were you using for that test? And if you don't mind me asking what are the cam specs? We are testing on out SF902 and having issues with the dyno and our EMC engine. See ya at the Challenge I think we have much to discuss. J.Rob (SKMFX engines)
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 2009 Engine masters dyno #s [Re: W5DART66] #474051
09/21/09 10:25 AM
09/21/09 10:25 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
That was a little higher than I expected on Rider's dyno.
Not bad for a pump-gas engine, huh?
EM rules allow up to 11.5:1 compression ratio.
Re: 2009 Engine masters dyno #s [Re: S/ST 3040] #474052
09/21/09 11:12 AM
09/21/09 11:12 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey Vic, what cam and intake rocker ratio?
Re: 2009 Engine masters dyno #s [Re: emarine01] #474053
09/21/09 11:20 AM
09/21/09 11:20 AM
S/ST 3040 Offline
S/ST 3040  Offline
Please forgive me, if I don't tell. Brett might. (I hope not)
Re: 2009 Engine masters dyno #s [Re: S/ST 3040] #474054
09/21/09 11:29 AM
09/21/09 11:29 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Humm How about a hint, are the .050#s bigger than that cam cut on a 109 that you are sittin on
Re: 2009 Engine masters dyno #s [Re: emarine01] #474055
09/21/09 11:52 AM
09/21/09 11:52 AM
S/ST 3040 Offline
S/ST 3040  Offline
Not even close.
Re: 2009 Engine masters dyno #s [Re: S/ST 3040] #474056
09/21/09 12:54 PM
09/21/09 12:54 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Cool, it looks like you guys are on to something out of the norm
Re: 2009 Engine masters dyno #s [Re: emarine01] #474057
09/21/09 01:28 PM
09/21/09 01:28 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Ooops, I forgot to wish you guys good luck, I thought it was already over
Re: 2009 Engine masters dyno #s [Re: emarine01] #474058
09/21/09 02:38 PM
09/21/09 02:38 PM
SoCal
Brian Hafliger Offline
SoCal
Have a for me when your there. Maybe next year we can get together somehow....
Brian Hafliger
Re: 2009 Engine masters dyno #s [Re: Brian Hafliger] #474059
09/21/09 10:18 PM
09/21/09 10:18 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
cam specs
255 at .050" intake 283 at .020" .427" lobe
266 at .50" exhaust 298 at .020" .427" lobe
intake on 104 exhaust on 112 cam is in at 102.5
Has 1.65 rockers intake and exhaust cam is ground on a 1.085 " BC springs are (PSI brand) 300lbs on the seat 750 lbs over the nose.
Re: 2009 Engine masters dyno #s [Re: W5DART66] #474060
09/22/09 09:04 AM
09/22/09 09:04 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Thankx Brett, I just learned more than you could ever imagine, Is the intake lobe fast enough not to fly cut?
Re: 2009 Engine masters dyno #s [Re: emarine01] #474061
09/22/09 09:08 AM
09/22/09 09:08 AM
S/ST 3040 Offline
S/ST 3040  Offline
Are you still looking for a bigger cam?
