HELP!! Car will not start... #473918
09/20/09 08:14 PM
09/20/09 08:14 PM
Branson, Southwest MO
Scat_Pack Offline OP
Hello, I have a 76 coronet cop car, it will not start, it acts just like a bad ballast resistor, but it is good, you know starts when in the start position but dies when in the run position, any ideas? Could it be the ingition module? I have never had one do this. Jim
1941 ford coupe Chopped 6"
1966 VW Chopped 6"
1966 plymouth Belvedere II special order 999 paint code Petty Blue
1964 Dodge dart GT convertible
1971 340 Cuda
3 1969 Superbee's
"Anyone can restore a car, it takes a real man to cut one up!"
Re: HELP!! Car will not start... [Re: Scat_Pack] #473919
09/20/09 08:29 PM
09/20/09 08:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You have two ignition spots and wires in the ignition switch. Make sure you are getting power from the switch to the ballast in the run position.
Re: HELP!! Car will not start... [Re: stumpy] #473920
09/20/09 10:02 PM
09/20/09 10:02 PM
MNobody Offline
MNobody  Offline
Check for power at the coil too.
Re: HELP!! Car will not start... [Re: MNobody] #473921
09/20/09 10:29 PM
09/20/09 10:29 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
bad pick-up in the distributor?
Re: HELP!! Car will not start... [Re: Scat_Pack] #473922
09/21/09 08:03 AM
09/21/09 08:03 AM
Switzerland, Europe
Swiss_Robert Offline
Switzerland, Europe
Connect the coil direct to battery with a temporary cable - just to test if it's about an electrical issue.
(Well, and of course start the engine then and see if it runs...)
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: HELP!! Car will not start... [Re: Swiss_Robert] #473923
09/21/09 08:18 AM
09/21/09 08:18 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
You are sure that the ballast is goodf?? Did you replace it?
Re: HELP!! Car will not start... [Re: MoparforLife] #473924
09/21/09 08:41 AM
09/21/09 08:41 AM
NJ
440challenger Offline
NJ
dizzy pickup
Re: HELP!! Car will not start... [Re: 440challenger] #473925
09/21/09 09:41 AM
09/21/09 09:41 AM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Yep some of the 70's distributors had dual pick ups, one for start and one for run.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: HELP!! Car will not start... [Re: johnedod] #473926
09/22/09 10:46 AM
09/22/09 10:46 AM
North Central Indiana
C-Tech Offline
C-Tech  Offline
you can switch the conectors around and see if it started when you let off the key, I have seen a couple of those run / start pickups fail on just one side
Kevin
