Re: WHAT KIND OF PAINT TO PUT ON THE BOTTOM MY RACECAR???
[Re: mopars rule]
#473871
09/20/09 08:56 PM
09/20/09 08:56 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I like to use gloss black rustolium as its affordable and does a nice job. Ron
[Re: topside]
#473875
09/20/09 11:16 PM
09/20/09 11:16 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
any automotive paint that is an epoxy or has a catalist hardener..should work real good and be durable.. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: GomangoCuda]
#473879
09/22/09 11:07 AM
09/22/09 11:07 AM
Posts: 543 Indiana, Just Off I-70
BradD
PPG Delfleet Essential! Low cost polyurethane enamel. Nice gloss, single stage, good coverage, durable. Uses a hardener and an activator, no reducer needed. Will be easy to clean once cured. Brad Dorn Autocraft LLC
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
