WHAT KIND OF PAINT TO PUT ON THE BOTTOM MY RACECAR??? #473870
09/20/09 07:55 PM
09/20/09 07:55 PM
alabama
mopars rule Offline OP
mopar addict
mopar addict
alabama
I am almost finished cleaning all the rubber undercoat off the bottom of my Duster. What type of paint should I go back with to resist any oil and debris? What do you fellas use? Or will regular automotive paint be fine? This will by no means be show worthy under the car just want to clean it up a little, by the way the only driving it will see is on the strip an 1/8 th of a mile at a time.
Re: WHAT KIND OF PAINT TO PUT ON THE BOTTOM MY RACECAR??? [Re: mopars rule] #473871
09/20/09 08:56 PM
09/20/09 08:56 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I like to use gloss black rustolium as its affordable and does a nice job. Ron
Re: WHAT KIND OF PAINT TO PUT ON THE BOTTOM MY RACECAR??? [Re: 383man] #473872
09/20/09 10:03 PM
09/20/09 10:03 PM
alabama
mopar addict
mopar addict
alabama
I have considered that. But I wouldn't mind using the spray gun to cover such a large area. The whole bottom of the car plus the rearend.
Re: WHAT KIND OF PAINT TO PUT ON THE BOTTOM MY RACECAR??? [Re: mopars rule] #473873
09/20/09 10:05 PM
09/20/09 10:05 PM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
Rust Bullet. I use lots of it and swear by it. Its highly resistant to gas and oil too.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: WHAT KIND OF PAINT TO PUT ON THE BOTTOM MY RACECAR??? [Re: maundmotorworks] #473874
09/20/09 10:34 PM
09/20/09 10:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A medium to light color makes it easier to see the undercarriage; black hides things - and burnout rubber - but it's harder to see what you're working on.
Re: WHAT KIND OF PAINT TO PUT ON THE BOTTOM MY RACECAR??? [Re: topside] #473875
09/20/09 11:16 PM
09/20/09 11:16 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
any automotive paint that is an epoxy or has a catalist hardener..should work real good and be durable..
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: WHAT KIND OF PAINT TO PUT ON THE BOTTOM MY RACECAR??? [Re: cheapstreetdustr] #473876
09/21/09 01:06 AM
09/21/09 01:06 AM
fullmetaljacket Offline
high gloss finishes will help the chassis slice through the under carriage currents much better than flats or even semi-glosses.
Re: WHAT KIND OF PAINT TO PUT ON THE BOTTOM MY RACECAR??? [Re: mopars rule] #473877
09/21/09 01:31 AM
09/21/09 01:31 AM
I like to use the thin black undercoating that comes in the spray cans and glossy black engine paint on the rear end
Re: WHAT KIND OF PAINT TO PUT ON THE BOTTOM MY RACECAR??? [Re: fullmetaljacket] #473878
09/22/09 10:36 AM
09/22/09 10:36 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I doubt that he will be going fast enough in the 1/8 mile for that to make any measurable difference.
Re: WHAT KIND OF PAINT TO PUT ON THE BOTTOM MY RACECAR??? [Re: GomangoCuda] #473879
09/22/09 11:07 AM
09/22/09 11:07 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
PPG Delfleet Essential! Low cost polyurethane enamel. Nice gloss, single stage, good coverage, durable. Uses a hardener and an activator, no reducer needed. Will be easy to clean once cured.
Brad
Dorn Autocraft LLC
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: WHAT KIND OF PAINT TO PUT ON THE BOTTOM MY RACECAR??? [Re: BradD] #473880
09/22/09 12:18 PM
09/22/09 12:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I like the gloss paint as it is easier to clean off. Ron
