8 3/4 Detroit Lockers #473823
09/20/09 07:28 PM
09/20/09 07:28 PM
Portland Oregon
JohnnyBeGood Offline OP
Portland Oregon
I want to use one of these in a 742 case anyone using these? Do I just buy a non posi case with gears and add the locker to it? Sorry about about the dumb question! What are the best makers og these? Thanxs
Re: 8 3/4 Detroit Lockers [Re: JohnnyBeGood] #473824
09/20/09 07:34 PM
09/20/09 07:34 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
There is only 1 Detroit Locker. It is made by Eaton.
The unit comes assembled. If you swap it into an original third-member, you must press on bearings, install the ring gear and set the backlash.
Re: 8 3/4 Detroit Lockers [Re: DoctorDiff] #473825
09/20/09 09:13 PM
09/20/09 09:13 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have had a Detroit Locker in my 63 for 2 years now. I like it alot but it will make some clunk noise when turning sometimes. No big deal as it mechanicly will unlock one wheel when turning and then lock it back in when straight. Sometimes I feel it unlock or lock back in but it has worked great for me. Ron
Re: 8 3/4 Detroit Lockers [Re: 383man] #473826
09/20/09 09:16 PM
09/20/09 09:16 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I'd look into getting my parts from Dr. Diff! That said, my lockers in both Dana 60 and 8.75 work great on the street, although I don't drive in the rain much.
Re: 8 3/4 Detroit Lockers [Re: 383man] #473827
09/21/09 12:08 PM
09/21/09 12:08 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Not sure if you're interested in them but I'm using a Powertrax Lock Right in my A-body 8-3/4.
Yes it has the slight clunking noise around slow turns too.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: 8 3/4 Detroit Lockers [Re: MY340] #473828
09/21/09 01:34 PM
09/21/09 01:34 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Detroit Tru-Trac ftw!
Re: 8 3/4 Detroit Lockers [Re: MY340] #473829
09/21/09 05:00 PM
09/21/09 05:00 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I just took the powertrax lock rite out of my Dakota and went with a spool. Was not happy with it, on powerful launches it would unload one side.
