New best Gas mileage 23.4 MPG at 70 MPH #473767
09/20/09 06:57 PM
09/20/09 06:57 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Did some tweaking on my new Thermoquad. Car runs really well. Can't wait to get the vacuum advance hooked up. Maybe 25 MPG is possible? Car is my 408 Duster you see in my sig.
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: dmerc] #473768
09/20/09 08:08 PM
09/20/09 08:08 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
awesome work. i see you also have an OD trans. i bet that really helps. the 700R4 has pretty good ratios if i'm not mistaken.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: Jerry] #473769
09/20/09 08:10 PM
09/20/09 08:10 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
I get 21mpg from my stock 340 4 speed with a 2.76 gear.
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: Jerry] #473770
09/20/09 08:47 PM
09/20/09 08:47 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Yup The overdrive trany really helps and the carb is a perfect match. Good mileage on the 340 too. I think high compression motors can get some good mileage mine is 10.5 to one and the dynamic compression is right at 8.5
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: dmerc] #473771
09/20/09 10:37 PM
09/20/09 10:37 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
What rear gear are you running?
BTW the OD ratio in the 700R4 is not as good as the .69 OD in an A-500 or 518.
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: HotRodDave] #473772
09/20/09 11:48 PM
09/20/09 11:48 PM
Mooresville, NC
I
Intense RT Dan Offline
I
Mooresville, NC
I was curious how you got the 700r4 onto the magnum 408? Adapter? Who makes it?
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: Intense RT Dan] #473773
09/21/09 12:10 AM
09/21/09 12:10 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Howzabout some details on your whole rig?
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: vdriver] #473774
09/21/09 12:17 AM
09/21/09 12:17 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Isn't Keisler doing that swap? I know they did an automatic setup.
There are a few Mopars running around with that tranny. It usually causes a stink around here due to the non-Mopar origin.
- Stu Harmon
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: feets] #473775
09/21/09 12:24 AM
09/21/09 12:24 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Many companies sell the adapter plate for this, TCI is one of them.
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: HotRodDave] #473776
09/21/09 06:41 AM
09/21/09 06:41 AM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
I'm running a 3.23 rear end. The overdrive on the 700R4 is .70
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: feets] #473777
09/21/09 06:46 AM
09/21/09 06:46 AM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Yeah, i don't understand that. This is about hotrodding, experimenting and learning. I like all brands. They all have something to contribute IMHO. By the way, really like your car!
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: goldmember] #473778
09/21/09 06:59 AM
09/21/09 06:59 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
any idea if that same adapter will also work
for the new six speed 6L80 automatic too?
http://en.wikipedia.org/wiki/GM_6L80_transmission
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: vdriver] #473779
09/21/09 06:59 AM
09/21/09 06:59 AM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Used a Wilcap adapter. The engine is a quench design with a .508 lift mild 4X4 grind cam. Makes over 400ft/lb of torque at 2000 RPM. Using regular Mopar ignition. Engine is a stroked Roller cam. Opened up the bowls in the heads and blended the transition. Stock valve job. 340 HP manifolds and TTI 2 1/2 exhaust system. Spins the 275/60-15 tires pretty easy
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: 360view] #473780
09/21/09 07:05 AM
09/21/09 07:05 AM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
I'm not sure. Best to get a hold of the Wilcap company. Man,that would be the balls wouldn't it??
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: dmerc] #473781
09/21/09 08:53 PM
09/21/09 08:53 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
The thing I never liked about the 700R4 is the big ratio spread between 1st and 2nd. The 2004R had a much better ratio spread throughout all the gears. Man, can't wait to get my 440 518 Dart rolling!!!
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: teflon] #473782
09/21/09 09:06 PM
09/21/09 09:06 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Actually the biggest jump is 3rd to 4th. I had to put a lower stall converter in because the car would spin through first, hit second and keep spinning. With a big engine you don't notice the first to second jump at all. Your set up should be sweet. Wait till you hit overdrive. It will put a big smile on your face
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: dmerc] #473783
09/21/09 09:44 PM
09/21/09 09:44 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
Impressive
the 408 Magnum I have in my pickup has gotten as high as 17 mpg; in a 4400-lb truck that runs 13s, I'll take it!
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: dmerc] #473784
09/21/09 10:45 PM
09/21/09 10:45 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Depends on how far you want to go. I think you have everything scienced out to a "T". All I can come up with to help you get that number is:
1. Pull the 275's off and replace with 235-70-15. They are the same height as the 275 and will get rid of a few inches of rolling resistance.
2. Put 215's or better yet 195's on the front.
3. Go 60 mph
Some more drastic measures:
4. Lock-up torque convertor.
5. Lower the car as much as practical.
6. 3.08's
Nice to see you are making progress on your project
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: Grizzly] #473785
09/22/09 12:45 AM
09/22/09 12:45 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Great work Dmerc. I've always had a feeling Tquads had potential. That cam is probably helping too. Does it run clean under 2000rpm?
Can't wait to see your before and after vacuum advance numbers too.
Is your comp ratio 10.5 or 8.5 to 1.
I've cracked 20 also. My 87 Ram, reg cab, shortbox has a 5.9 Magnum, 670 Holley, M1 dual plane, short headers. Then a 5 spd manual w 0.73 od and 3.55 gear and a 28" tire. Straight highway at just under 70 mph has returned 23 mpg. I'm pretty sure aero dynamics is my biggest roadblock in the quest for mileage.
Re: New best Gas mileage 23.4 MPG at 70 MPH [Re: dmerc] #473786
09/22/09 12:51 AM
09/22/09 12:51 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How is that 700R4 holding up? I heard they need some help to survive behind a healthy motor in a heavier car?
