Which is Better: Hood Scoop Question #473390
09/20/09 01:33 PM
09/20/09 01:33 PM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
I'm going to make a better carb baseplate w/ foam to seal to my hoodscoop (68 S/S style). The hole in the steel hood is round. Which would be a better style to use and modify as the center; a flat base or a drop base? Thanks in advance, KK.
Re: Which is Better: Hood Scoop Question [Re: Kudakidd] #473391
09/21/09 05:39 AM
09/21/09 05:39 AM
Kudakidd Offline OP
Kudakidd  Offline OP
Wait a minute. Ya mean on one in the RACE SECTION uses a hood scoop?
Re: Which is Better: Hood Scoop Question [Re: Kudakidd] #473392
09/21/09 06:56 AM
09/21/09 06:56 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
the bottom base looks better than the top base.
Re: Which is Better: Hood Scoop Question [Re: Kudakidd] #473393
09/21/09 12:41 PM
09/21/09 12:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
no , they use COWL hoods
Re: Which is Better: Hood Scoop Question [Re: JohnRR] #473394
09/21/09 05:08 PM
09/21/09 05:08 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Oh you mean that CHEVY design?
Re: Which is Better: Hood Scoop Question [Re: Kudakidd] #473395
09/21/09 05:37 PM
09/21/09 05:37 PM
I have a six pack hood,an run no filter...
Re: Which is Better: Hood Scoop Question #473396
09/21/09 06:37 PM
09/21/09 06:37 PM
Galesburg IL.
dillon383 Offline
dillon383  Offline
Galesburg IL.
I would persoally use the second one. It doesn't look like it would disturb the air flow as much.
Re: Which is Better: Hood Scoop Question [Re: dillon383] #473397
09/21/09 08:44 PM
09/21/09 08:44 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I use a drop base with a notch cut out for the linkage and a K&N Stub Stack. Ran back to back last Sunday: 11.46 with, 11.55 without, 11.43 with stub stack.
Re: Which is Better: Hood Scoop Question [Re: MoparforLife] #473398
09/21/09 09:08 PM
09/21/09 09:08 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Is the drop base sealed to the hood scoop?
Re: Which is Better: Hood Scoop Question [Re: Kudakidd] #473399
09/21/09 10:03 PM
09/21/09 10:03 PM
Upper Midwest
Upper Midwest
quote]Is the drop base sealed to the hood scoop?
Yes, as pictured with the foam.
Re: Which is Better: Hood Scoop Question [Re: Kudakidd] #473400
09/21/09 11:17 PM
09/21/09 11:17 PM
K.K., no two cars are exactly identicle Do both and test them at the track and sell the worst one
Re: Which is Better: Hood Scoop Question [Re: MoparforLife] #473401
09/22/09 05:56 AM
09/22/09 05:56 AM
Kudakidd Offline OP
Kudakidd  Offline OP
quote]
Thanks Moparforlife, That's just what I was looking for.
