First time out with new motor #473177
09/20/09 09:54 AM
09/20/09 09:54 AM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
Took the car out to Lapeer yesterday for some T&T. It ran good, a best of 12.35 @ 113.32 and that was with a 2.0 60ft. Good MPH for this combo,I need to work on traction first then fine tune.
The Car: 73 Challenger 416 stoker 10.5 cr. Comp hydraulic 250* with .525 lift M1 single plane w/holley vac secondary 750 Hooker SC 1 3/4" thru 2 1/2 pipes to dynomax super turbos exiting at the axle. 727 with a 3500 stall 10" convertor to 4.30 gears on BFG 275/60x15 drag radial @18psi.
I have the rear springs clamped but I'm thinking Super stock springs and a Pinion snub should be the next step.
the car weighs in at 3780 with me in it(yea I know get out and lighten the car 200lbs). I have a set of e-body SS springs rate for 3300lbs. do you guys think these would be worth a shot or should I sell them and pick-up Higher rated springs(3600 or 3800)?
thanks
Re: First time out with new motor [Re: Mr340] #473178
09/20/09 10:02 AM
09/20/09 10:02 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
They will work fine and you will take a beating selling the ones you have...
Re: First time out with new motor [Re: Mr340] #473179
09/20/09 12:32 PM
09/20/09 12:32 PM
Before you change the springs buy a set of good drag tires As far as a pinion snubber don't waste your time or money, a good set of springs will never let the snubber hit the floor The springs you have should work well with a good set of tires as long as the rear shocks are not topping out Did you clamp the front half or all of the springs?
Re: First time out with new motor [Re: Cab_Burge] #473180
09/20/09 04:14 PM
09/20/09 04:14 PM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
I clamped the front segment. The shocks are the Mopar drag shocks, should be long enough, but a good idea to verify.
A "Good Drag tire" being Slicks? Or Mickey Street radials?
Re: First time out with new motor [Re: Mr340] #473181
09/20/09 06:15 PM
09/20/09 06:15 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
I'm curious too...what is a good drag radial?
Re: First time out with new motor [Re: Cab_Burge] #473182
09/20/09 06:26 PM
09/20/09 06:26 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
And a good set of adjustable shocks to get the car transfering weight. I bet the car will run 11s with a good setup...not bad for Lapeer
Re: First time out with new motor [Re: B1Fish540] #473183
09/20/09 06:35 PM
09/20/09 06:35 PM
Hemiroid Offline
Hemiroid  Offline
Your mph says 11.90's, so get that 60' down to 1.65 or so and it should be high 11's all the time.
Re: First time out with new motor [Re: Hemiroid] #473184
09/20/09 06:49 PM
09/20/09 06:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
With 113 you have easy 11.80's with good hook. Get a good tire under it and like was said a good shock up front to transfer weight. Good luck , Ron
Re: First time out with new motor [Re: Shaker223] #473185
09/20/09 07:42 PM
09/20/09 07:42 PM
Renton Washington
Triple Threat Offline
Renton Washington
A M/T ET street radial is all I've had on my car. I've been 1.62 60 foot on a 235/60/15 with some old worn out super stock springs.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: First time out with new motor [Re: 383man] #473186
09/20/09 10:19 PM
09/20/09 10:19 PM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
Currently I have Mopars' hi-performance handling shocks on the front, I have a pair of CE 90/10's I can swap out. I double checked the rear shocks and they are MP's drag shocks. I'll install the SS springs and look for a stickier rear tire. Elevens here I come!
Thanks,
Gary
Re: First time out with new motor [Re: Mr340] #473187
09/20/09 11:56 PM
09/20/09 11:56 PM
Do you have a old set of front shocks that you don't need If so drill them at the bottom and drain them first(be careful,don't get any of that stinky oil on you ) before buying a set of 90-10 race shocks I have tested a lot of front shocks on different cars, I now have the Koni SPA on the front of my street car ( BB powered 1971 duster)that runs 1.43 60 ft. times on M/T ET Street Radails Those shocks are good shock for both the strip and street, they are speed sensing according to Koni BTW, if you want a set you have to buy the ones for the B bodys as Koni doesn't list them for A bodys like our cars
Re: First time out with new motor [Re: Cab_Burge] #473188
09/21/09 07:53 AM
09/21/09 07:53 AM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
Cab the CE's I already have. they are adjustable, 90/10, 70/30 and 50/50 I think. I can try these but if I'm not happy with them I may look into the Koni's, I like the idea of a good steet/strip shock better than a race shock since the car does see plenty of street time.
Thanks,
Gary
