what do you think about my cam? #473136
09/20/09 09:30 AM
09/20/09 09:30 AM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
its going in 500",indy 440-1,drag car 3000lb,p/g trans,4.86 gear.comp,.630 int,.642 ex,.050 271 int,275 ex,110 lobe sep.thanks,sam
Re: what do you think about my cam? [Re: sam64] #473137
09/20/09 09:54 AM
09/20/09 09:54 AM
gregsdart Offline
gregsdart  Offline
Should work well, install it advanced to help with the glide. Use a very loose converter if you have the option on stall, 5500+. With a loose converter, a 500 inch 440-1 motor will run well with durations up to 284 @ .050 on the intake, and if the heads have been ported, all the lift you can muster. My best results have been with a roller of 283/296/110 with .775 int .680 ex. although I do have more cubes at 528.
