How to measure compression height on a piston.
#473028
09/20/09 01:44 AM
09/20/09 01:44 AM
Posts: 735 Spokane,WA
Genuinejed
Spokane,WA
I assume the measurement is from the center of the piston pin, so distance from top of pin hole to top of piston + half the diameter of pin hole, right? I'm trying to find a set of low compression pistons for a Blown 440 project and the ones I have measure 2.071 using the above method. I'm thinking these are not the ones to use. Thanks!
1968 Plymouth road runner
1968 Dodge Coronet 500
64 D200
Good, Fast, Cheap. Pick Two.
Re: How to measure compression height on a piston.
[Re: Genuinejed]
#473031
09/20/09 03:06 PM
09/20/09 03:06 PM
Genuinejed
Spokane,WA
Kool! Thanks guys. These are just stock replacement pistons, I wanted to find out if they're the 8 to 1 or 10 to 1 variety. Looks like they are the higher compression version. I'm thinking I might use them in my street car. Do you think it would be a good idea to machine the block for zero deck and use these with my 915s? are these good pistons to use in a quench motor? The only number I can find is B278. I'm thinking they're Badger?
64 D200
[Re: TheOtherDodge]
#473032
09/20/09 03:15 PM
09/20/09 03:15 PM
Posts: 5,875 communist bloc of new jersey
jamesc
And if you really want to get to the nitty gritty, the area between the top of the ring and the head!
look at the calculator smartypants it's in there
as for what to do with those pistons it really depends on your goals. no matter what you should do the math to see exactly where you'll end up before machining anything.
