Re: Off-Set Lifter with 440-1 Indy heads...
[Re: Brian Hafliger]
#472932
09/19/09 11:03 PM
09/19/09 11:03 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Brian, where is the oil feed passage that feeds the roller wheel bearings? Billy, I bought a set from Brian, they are a great way to increase life of the lifters. I have two used sets of non oiling roller lifters with bad bearings in some of them,,,,,,,,,,,
[Re: gregsdart]
#472933
09/19/09 11:19 PM
09/19/09 11:19 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
If you look in the pic above, look at the closest lifter body, where the oil hole in the side of the body is....then pan down to the bottom of the "cutout" and you can barely see it in the pic. It's edge orfice oiling and it's not part of the pushrod oiling system.
Brian Hafliger
[Re: 68roadrunner]
#472935
09/19/09 11:37 PM
09/19/09 11:37 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I run Isky red zone lifters with offset and pushrod oiling on my -1 heads. So far I've had no problems with them.
[Re: BILLYJAY]
#472938
09/20/09 12:12 AM
09/20/09 12:12 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
It might put more oil up top...you'd have to check it because I've never built an engine with both ways functioning. It helps to have oil in the pushrod, helps cut down on harmonics.
Brian Hafliger
#472943
09/20/09 10:09 AM
09/20/09 10:09 AM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
I recommend our .180 offset lifter. Pushrod oiling, oils the bearings, will work with up to .470 lobes and no lifter bore bushings.
Brian, How does that lifter differ from the 892's? Mike
