BB Oil pump loses prime #472865
09/19/09 08:20 PM
09/19/09 08:20 PM
Cedar Rapids, IA
69Mcode440 Offline OP
Cedar Rapids, IA
I have the milodon pan with the static remote pickup and the Muscle Motors pump cover. This car is an original 69 Cuda 440 car so the k-member supports for the steering box require the line to the pan to go around the k-member as the pictures show.
I have primed the oil pump three times by breaking the connection at the bottom of the curved tube and shooting lubriplate into the suction side of the pump and then running the pump with a drill. It primes right away and I ram the pump for about 5 minutes. I waited for 1 minute, started the drill, pressure ok, then 5 minutes, started the drill, pressure ok. Then after 30 minutes and checked prime again, and no pressure.
Any ideas would be greatly appreciated.
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car Best et 9.32, 145.9 mph
2019 Ram 2500 4x4
Re: BB Oil pump loses prime [Re: 69Mcode440] #472866
09/19/09 08:35 PM
09/19/09 08:35 PM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
It might help if you could run a section of line above the pump then connect it to the inlet on the pump. What
little bit of oil in the line would rest against the pump keeping it "primed". Kinda like whats pictured below. I noticed with the MM pump cover that I'll loose prime after 2 weeks of setting. My Milodon never did that. Could set all winter and still have oil pressure at startup. Thank goodness for an oil accumalator!
Re: BB Oil pump loses prime [Re: Gearhead383] #472867
09/19/09 08:46 PM
09/19/09 08:46 PM
Cedar Rapids, IA
Cedar Rapids, IA
Is your cover a mm cover? Yours exits the back of the pump, mine out the top (or bottom).
Mike
69 440 Cuda
71 Dart drag car
2019 Ram 2500 4x4
Re: BB Oil pump loses prime [Re: 69Mcode440] #472868
09/19/09 09:02 PM
09/19/09 09:02 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Here's how mine are. Zero problems. You need to figure away to put a loop in it.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Post deleted by Defbob [Re: bigtimeauto] #472869
09/19/09 10:16 PM
09/19/09 10:16 PM
Re: BB Oil pump loses prime #472870
09/19/09 11:01 PM
09/19/09 11:01 PM
gregsdart Offline
gregsdart  Offline
you have an air leak
This can be caused by excessive clearance in the pump to end plates. It takes very little extra clearance to create problems. A high point in the lines will fix you up.
Re: BB Oil pump loses prime [Re: gregsdart] #472871
09/19/09 11:14 PM
09/19/09 11:14 PM
Cedar Rapids, IA
Cedar Rapids, IA
Thanks for the help! I will have to figure out how to route the line to put a high loop in it.
Mike
69 440 Cuda
71 Dart drag car
2019 Ram 2500 4x4
Re: BB Oil pump loses prime [Re: 69Mcode440] #472872
09/20/09 12:21 AM
09/20/09 12:21 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
when you reroute it get it above the k frame that is scary and an accident waiting to happen.
Re: BB Oil pump loses prime [Re: TS3303] #472873
09/20/09 10:21 AM
09/20/09 10:21 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
if that is going to get raced I wouldn't be surprised if a tech inspector told you to come back once you got that fixed .
Re: BB Oil pump loses prime [Re: 69Mcode440] #472874
09/20/09 10:33 AM
09/20/09 10:33 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Yes you have to loop the line up above the pump, I have mine almost to the head then down to the pump. By the way , what's that long bolt doing hanging down from the cross member, looking for a flat tire?
Post deleted by Defbob [Re: 69Mcode440] #472875
09/20/09 10:51 AM
09/20/09 10:51 AM
Re: BB Oil pump loses prime #472876
09/20/09 12:44 PM
09/20/09 12:44 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Which oil filter are you using?
I had the same problem and it was the oil filter that was causing the problem. The anti-drainback valve was not sealing.
Joe
Without Data, you’re just another guy with an opinion.
Re: BB Oil pump loses prime [Re: sr4440] #472877
09/20/09 04:23 PM
09/20/09 04:23 PM
Cedar Rapids, IA
Cedar Rapids, IA
The oil filter is a WIX. The long bolt connects to the torque strap, not yet connected.
The oil line is getting relocated. BTW the oil line is well above the bottom of the pan...it will probably take more abuse than the oil pan IMO.
Thanks for the feedback.
Mike
69 440 Cuda
71 Dart drag car
2019 Ram 2500 4x4
Re: BB Oil pump loses prime [Re: 69Mcode440] #472878
09/20/09 08:18 PM
09/20/09 08:18 PM
Cedar Rapids, IA
Cedar Rapids, IA
Here are the pics with the re-routed line.
Got good oil pressure now. I hope it holds prime. It held 2 hours between running so far.
Thanks for all the help.
Mike
69 440 Cuda
71 Dart drag car
2019 Ram 2500 4x4
Re: BB Oil pump loses prime [Re: 69Mcode440] #472879
09/20/09 10:28 PM
09/20/09 10:28 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
I dont have the external pickup on mine but if i go this route i may consider a one way flow valve (check valve)
Re: BB Oil pump loses prime [Re: Cheatham] #472880
09/20/09 10:30 PM
09/20/09 10:30 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
no need at all and would proably cause more issues.
Re: BB Oil pump loses prime [Re: Cheatham] #472881
09/20/09 10:39 PM
09/20/09 10:39 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Or you could get a Titan pump and not have to worry about it. My Milodon pump did the same thing, no way I was putting that junk on my new motor.
