Post deleted by Defbob
#472694
09/19/09 03:52 PM
09/19/09 03:52 PM
Re: p/g trans bake not working ??
#472695
09/19/09 04:00 PM
09/19/09 04:00 PM
Posts: 705 Michigan
Hemiroid
just installed new ATI case. used all the old parts from last trans. t/b not holding in low but works in reverse? disconnect cable to eliminate any problems there. Never heard of a similar problem but was concerned about any shimming of solenoid to correct it.
It's just confused from being in the wrong brand of car
[Re: Hemiroid]
#472696
09/19/09 04:12 PM
09/19/09 04:12 PM
Posts: 6,314 The Swamp
MegaDart
The Swamp
did you use the same valve body and selanoid?? If not your selanoid is probably too short. I believe they come in 3 different lenghts, the throw on the plunger that is. edit: just read you reused all the parts. My guess is the case is thicker at the selanoid mount making yours to short? just a thought
[Re: MegaDart]
#472697
09/19/09 04:30 PM
09/19/09 04:30 PM
[Re: MegaDart]
#472699
09/19/09 04:57 PM
09/19/09 04:57 PM
#472701
09/19/09 05:38 PM
09/19/09 05:38 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Fred Just curious...How is the case made in the back to allow the standard and Double dump style (pro brakes)...This is the place were we use to drill the case through near the reverse piston? I would imagine it would have plugs or something?
Just wondering..
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: MegaDart]
#472702
09/19/09 05:42 PM
09/19/09 05:42 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Ran into the exact same thing when I went to the BTE Pro-Brake Valve Body from my ATI Brake....I used the ATI Solenoid and the plunger was the wrong size....got the right one and it has worked flawlessly ever since
Rickster
#472703
09/19/09 06:23 PM
09/19/09 06:23 PM
#472705
09/19/09 07:17 PM
09/19/09 07:17 PM
rickstershemi
note all internals from previous trans were used . no new parts added . same v/body and it all worked
If you still have the old case...maybe ck the thickness where the solenoid mounts for any difference....just a thought....mine did the same as Waynes = same symptom as yours
Rickster
[Re: emarine01]
#472707
09/19/09 08:40 PM
09/19/09 08:40 PM
[Re: 68roadrunner]
#472709
09/20/09 12:20 AM
09/20/09 12:20 AM
[Re: 68roadrunner]
#472711
09/20/09 09:46 AM
09/20/09 09:46 AM
