build my LA 360,. advice needed, PLEASE
#472626
09/19/09 02:15 PM
09/19/09 02:15 PM
Posts: 715 Tulsa, Oklahoma
Charger_440
Tulsa, Oklahoma
i posted this in the Q&A as well, but im neeeding as much help as i can get, so here we go.
i posted a similar post last week wth little to no response. i am needing advice to assist me in building my 360 to get what i want out of it. its a 74 model LA 360. it will be going into a 74 charger w/an a-500 tranny.
what i want is to have a street friendly build and i my HP goal is 360-400...no more than 400. let's plan around a 4bbl and stock manifolds but i will eventually be going to tbi. i already have an ex262 comp cam that i can use in it. i need to know what will be needed for this build. i do not want a thirsty beast, or a race build. just enough power to play around with when i push the pedal. where cost is concerned, let's aire on the less expensive side if we can..... can someone, anyone, give me some real world advice on how i can attain my build goals. if i can do it without boost, then i prefer to. i am needing advice on internals. the more opinions the better,
some questions i am wondering about are things like... stock dished pistons vs flat what pistons can i use w/o having to change valves. hp capability of stock heads(after porting) i need to know it all, dont leave anything out or take anything for granted. if you say use different pistons, tell em what else i need to change in order to use them... any and all advice is greatly appreciated! i want to learn here as well as getting opinions. thanks in advance guys.
In a conversation with a Wyoming State Patrolman... "A 318 ??!!! But I clocked you at 142 mph!!!"
Re: build my LA 360,. advice needed, PLEASE
[Re: Dartcuda]
#472629
09/19/09 03:03 PM
09/19/09 03:03 PM
Charger_440
Tulsa, Oklahoma
concerning the cam, what makes the cam determine the HP limits of the engine? these are the things i want to learn. i just have that cam sitting around already, how much bigger is the cam you guys are suggesting than what i have? so, then, what determines whether i want a HP build, or a torque build... i was under the impression that HP was what made the motor feel "strong", but someone up above said it was torque. maybe i am using the term HP incorrectly. i am learning here, so with a 4k lb car, do i need to focus more on torque than power? or is there a balance to be found? also, some of you have said that the cam i have on the shelf is too small, what is the difference that the cam makes? what i want is an build that (with a 3.23 rear gear, etc) will MOVE that 4k lb car when i ask it to. Now understand, i am going from a 318 2bbl and 2.76 rear gear to this 360, so anything will be a big difference from what i did have. is torque what gives the push you back in the seat feeling, or hp? can anyone give me more info on a magnum head swap? there are plenty of trucks around here i can get heads off of, and i would likely have to go that route, rather than new mag heads...but i thought i would need to have water or oil passages redrilled or something, or that the bolt angles were different, i thought there was a bigger diff than just pushrods. thanks for all of your time, btw. i appreciate it. i just hope im not asking dumb questions....
