Help w/ air grabber how it works? #472607
09/19/09 01:02 PM
09/19/09 01:02 PM
west palm beach, florida
modelmakerinc Offline OP
Hey guys, I am looking for schooling on the operation of a 70-later Road Runner airgrabber scoop set-up. Not the air cleaner assembly but just the scoop part. How does it activate? any special parts?
any info would help. thanks Henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Help w/ air grabber how it works? [Re: modelmakerinc] #472608
09/19/09 01:37 PM
09/19/09 01:37 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
operates by vacuum
this might help
http://www.forabodiesonly.com/mopar/showthread.php?t=74515
Re: Help w/ air grabber how it works? [Re: 340dart4spd ] #472609
09/19/09 10:22 PM
09/19/09 10:22 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Vacuum operated.
Re: Help w/ air grabber how it works? [Re: SALEM1912] #472610
09/19/09 10:28 PM
09/19/09 10:28 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
If I remember vacuum held it shut and when you got on it the vac would drop and the door would open. I might be wrong it's been awhile.
Re: Help w/ air grabber how it works? [Re: modelmakerinc] #472611
09/19/09 11:48 PM
09/19/09 11:48 PM
Shoreline, Washington
72roadrunnergtx Offline
Simple dash mounted vacuum switch to open or close the A/G door. An ignition activated electrical solenoid valve on the open circuit would bleed off the “open” vacuum side when ignition was off, and switch left in the open position, allowing a actuator mounted spring to close the door. The system runs off a vacuum reservoir and is not responsive to changes in manifold vacuum directly.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Help w/ air grabber how it works? [Re: 72roadrunnergtx] #472612
09/20/09 08:04 AM
09/20/09 08:04 AM
Thanks guys, And You have a gorgeous 72 RR
Re: Help w/ air grabber how it works? [Re: modelmakerinc] #472613
09/20/09 09:59 AM
09/20/09 09:59 AM
Thanks,
Re: Help w/ air grabber how it works? [Re: 72roadrunnergtx] #472614
09/20/09 10:09 AM
09/20/09 10:09 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Thanks,
Do you have a picture of a 70 Coronet Ram Charger set up
Re: Help w/ air grabber how it works? [Re: 340dart4spd ] #472615
09/20/09 10:39 AM
09/20/09 10:39 AM
I don’t I’m afraid, pretty sure it was cable operated similar to the 69’ Plymouth “Fresh Air” system. The 71-72’ Dodge Ram Charger system was basically the same system as the 70-72’ Plymouth Air Grabber.
Re: Help w/ air grabber how it works? [Re: 72roadrunnergtx] #472616
09/20/09 10:41 AM
09/20/09 10:41 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
yes it was cable operated..
