Rear quarter windows--A-body's #472604
09/19/09 01:48 PM
09/19/09 01:48 PM
wisconsin
swifter Offline OP
swifter  Offline OP
wisconsin
Does anyone know if anyone reproduces the window seals for the piller side or front felts for the quarter windows on a body's--Dusters--not the rubber seal that goes around frame-Thanks Steve
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: Rear quarter windows--A-body's [Re: swifter] #472605
09/19/09 10:35 PM
09/19/09 10:35 PM
Delaware shore
68Barracuda Offline
68Barracuda  Offline
Delaware shore
I think your talking about the pop out post type window. If so the front felts next to the post are still available from the dealer. I don't know the number off hand but maybe someone will chime in. If it helps when you are talking with the parts guy they are actually the same part used in the front window channel. You just need to trim them for the quarter windows. I just did the ones in my 70 RR post car.
Re: Rear quarter windows--A-body's [Re: swifter] #472606
09/20/09 06:53 PM
09/20/09 06:53 PM
Outing, MN
beesuperA12 Offline
beesuperA12  Offline
Outing, MN
It is the same piece as the door glass vent channel on a B body. Legendary sells them. They are mopar pieces but they use their part # WS66C-BVENT, $42.50 each!! They come with the plastic guides.
69.5 Super Bee A12
