Re: Any 360 Magnum users out there? [Re: Intense RT Dan] #472298
09/24/09 12:23 PM
09/24/09 12:23 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I used a friends spring pressure tool, but with 15K miles on Sealed Power stock replacement springs I measured 80 on the seat and 270 open. With .060 shim...85 and 280. Still over .060 cbc.This is measuring at stock installed height, btw.
.060 shims will give you coil bind at ~.480" lift, so to keep a safe clearance you'd be limited to ~.420" valve lift, or less than the stock 318 mag cam.
2017 Grand Cherokee Overland
Re: Any 360 Magnum users out there? [Re: patrick] #472299
10/02/09 12:40 AM
10/02/09 12:40 AM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
assuming you have the correct valve spring setup, at what point do you need to start working about piston to valve clearance on a stock engine?
Re: Any 360 Magnum users out there? [Re: chache876] #472300
10/02/09 01:23 AM
10/02/09 01:23 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
You need to worry about P to V anytime you cam up. It's duration, rather than lift, that you have to worry about. At max lift the piston's far down the bore, but if the valve hangs open long, it could hit. There's no way to tell what the number is because if you advance or retard the cam, if the valve sizes are larger/smaller than stock, if the valve is sunk in the head, if the head is milled, thinner head gasket, etc. All these things play a part in what your piston to valve clearance will be and that's why nobody can give you more than a ballpark, "I had issues when I got to this large a cam" type of answer.
For what it's worth, I have a '97 magnum 360 in my car. Stock heads were cracked, 7 out of the 8 chambers. Bought Magnum R/T's and put LS6 chevy valves in 'em (I had them) .100" short but the geometry still worked. New pistons and rods, cam is a comp hydraulic roller, 216/224, .501" 114 LSA installed at 109. Was going to be a turbo motor. As is, with 1-5/8" headers and a perf RPM air gap intake it put 294 hp to the ground. Very mild combo. Built it for a truck as a matter of fact.
Shop I work at has a 360 with Edelbrock Mag heads. This one made 488 hp at the flywheel. Cam's a bit bigger than mine though and the heads have been worked over a bit... I like the magnums cause you can run a Chevy rocker arm. Cheaper and simpler. If you want to go crazy you can run T&D's...
Re: Any 360 Magnum users out there? [Re: chache876] #472301
10/02/09 01:23 AM
10/02/09 01:23 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Pro Comp has iron Magnum cyl hds for under $600.00 bare and likely are the same as the RHS cyl head.5.9L has a dished piston so there is a bit of clearance there.The 2.02 int valve is worth about 20 h.p in a slightly modified eng but you do lose some low end torque.350 h.p should be fairly easy to achieve with an int,decent headers,stock cyl hds w/the 2.02 int valve and the stock cam. The 5.9L Max that was schd for the 2000 m.y. made 320 h.p. with tri-y's,an int change,2.02's and the stock cam.The other area of concern is the distance between the bottom of the retainer and the top of the valve guide,very tight.
Leave the gun.......take the Cannoli's....Mike
Re: Any 360 Magnum users out there? [Re: mike s] #472302
10/02/09 02:02 AM
10/02/09 02:02 AM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
I've heard nightmares about the Procomp heads, bad reviews from the chevy crowd, they say there junk, i went with the RHSs for 875.00 complete from Hughes, they look very nice, & they flow good too with the stock valves.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Any 360 Magnum users out there? [Re: mike s] #472303
10/02/09 07:56 AM
10/02/09 07:56 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
pro comps are chinese cast heads that actually flow worse than OEM mags. if you want aftermarket mags, start out with the enginequests (cast in NZ) or the RHS's.
hughes has the EQ's advertised with OEM valves, & their 1110 springs for $699/pr assembled, the RHS's set up the same way they have for $175/pr more.
Re: Any 360 Magnum users out there? [Re: patrick] #472304
10/02/09 11:18 AM
10/02/09 11:18 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have had pretty much all the iron mag heads in my hands and the RHS and pro comp are litteraly the oposite ends of the spectrum. The RHS is the best and the pro-comp is the worst. The RHS has very nice machine work, very nice little touches aimed at improving wet flow, thick ports for lots of improvement, very good casting quality... The pro-comp has tiny ports with very rough castings, the only good thing about it is cheap price and the chamber is significantly smaller so you do get a compression bump.
Re: Any 360 Magnum users out there? [Re: HotRodDave] #472305
10/02/09 05:02 PM
10/02/09 05:02 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Thats why i went with the RHSs, i was very surprized at how nice the machineing was, they are heavy too, so there not going to crack anytime soon, plus theres room to port them & get some good #s, but stock they still flow good, those Procomps being around 600.00 bare is not even worth it, by the time you have them assembled with all the hardware, you'll be at what the RHSs cost if you bought everything new, & you still have junky heads, i also found a set off e-bay for 479.00 complete (new) from a place called J&C enterprizes, but luckally i got the scoop on them before i made my purchase.
Re: Any 360 Magnum users out there? [Re: patrick] #472306
10/02/09 05:25 PM
10/02/09 05:25 PM
Mooresville, NC
I
Intense RT Dan Offline
I
Mooresville, NC
That's incorrect on stock machined castings. On my OE stock unmachined spring pockets, stock retainers and locks,stock valves, and .060 shims...far from coilbind. This is at .471 gross lift, not counting any deflection, on the exhaust. Lift is .464 on the intake. I measured the cam on a cam doctor. I beat on the engine regularly pulling up to 6k rpms. It starts to float around 5800-5900. I'm still trying to determine best shift rpm from first gear.
I'm running V max roller lifters with .010 lash also. All on stock beehive/shimmed springs.Now, you do have to check and replace them more often.
Re: Any 360 Magnum users out there? [Re: Intense RT Dan] #472307
10/02/09 05:39 PM
10/02/09 05:39 PM
Mooresville, NC
I
I
Mooresville, NC
The EQ heads are great castings, I just wish the RHS heads were available last Dec when I ordered the EQ's. The larger stud boss would have been easier to setup the heads.
I wasn't going to use a 3/8 stud with only a 5/16 base so I drilled and tapped the EQ pedestals for a 3/8 base stud. I used arp studs for a Mark V BBC. 7/16 stud but with 3/8 base. I would have rather had the boss to drill and tap for a 1/2" base stud. The RHS would have allowed that. Guideplates are another problem. The Isky Adjustables holes are too big imo and just a pain in the rear dispite being tig welded. I want more surface area contacting the tiny pedestals of the EQ head. Again, would have that problem if I was using the RHS head. I'll get it sorted out, but I have many many hours developing the ports on these heads and wouldn't look forward to starting over. I think I'll digitize the ports and CNC machine some though when I finish CNC school.
Re: Any 360 Magnum users out there? [Re: Intense RT Dan] #472308
10/02/09 06:58 PM
10/02/09 06:58 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
I'm just going to run the stock rockers/pushrods for now, possibly even the cam (don't know yet) Tim @ Hughes said i'll be fine with a .503 lift cam on the stock stuff with the 1110 springs.
Re: Any 360 Magnum users out there? [Re: Intense RT Dan] #472309
10/05/09 08:00 AM
10/05/09 08:00 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
just stating what I physically measured with my OEM magnum heads. installed height on the stock, uncut heads and stock springs was 1.62". coil bind height, I measured at 1.1". that's .52" of travel before coil bind on my heads. figure .040" min clearance, that gives you .48" actual lift possible. add in .060 shims, and you have to reduce that by the same .060.
you must have some pretty decently sunk seats to be able to get that much lift with shims and stock parts.
