Any 360 Magnum users out there? #472278
09/19/09 01:31 AM
09/19/09 01:31 AM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
Just wondering how well you like them, i hear pros & cons on there perf. I'm hyped up about installing this 360 magnum i have in my Swinger, granted its stock, the only thing it'll have is headers/intake & carb, just wanting to see how well you like yours!
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Any 360 Magnum users out there? [Re: joedust451] #472279
09/19/09 02:05 AM
09/19/09 02:05 AM
Mooresville, NC
I
Intense RT Dan Offline
I
Mooresville, NC
Not exactly the same but...I have a '99 Dakota R/T and even with the stock cam they can run well. I'm running about a 13.4 corrected et with bolt ons. I'm still efi. Very mild head work to stock heads, Harland Sharp non adjustable rockers, Rhodes Vmax roller lifters set to .010 lash on stock 198 @.050 cam with .464 lift, m1 2bbl efi intake, 980 cfm throttle body, Edelbrock shorty headers, underdrive crank pulley, and electric fan. This is in a truck that weighs 3980lbs. No problems. Just do oil changes.
Re: Any 360 Magnum users out there? [Re: Intense RT Dan] #472280
09/19/09 02:23 AM
09/19/09 02:23 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
My goal is to be in the mid 12s (or better) with some spray (100-125 NX), other then the bolt-ons, i may add a small converter, plan on 3.55 gears & 26" DRs, don't know if the engine will achieve mid 13s NA in a 71 Dart running a stock cam/heads, i'm hoping it will.
Re: Any 360 Magnum users out there? [Re: joedust451] #472281
09/19/09 02:36 AM
09/19/09 02:36 AM
Mooresville, NC
I
I
Mooresville, NC
I don't see a problem there. Even possible NA.
I don't even have a higher stall yet, stock in mine is just shy of 1700. I have 3.92 gears and the gearing is just now getting to the point, since shifting peak hp higher, I need a little more.
What's the weight going to be? I think a stall around 2500 would work well being near stock. I think it would help me also.
As far as nitrous, I haven't run it, but the general concensus on a stock bottom end is that 100 is safe enough to run all day long. 150 is where it's possible to cause damage. I don't think you'll need that much to reach your goal.
Your 26" tires will help also.
Re: Any 360 Magnum users out there? [Re: Intense RT Dan] #472282
09/19/09 07:50 AM
09/19/09 07:50 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I have a 97' 5.9 with a 4" crank, iron heads and the mp .501/.513 circle track hyd roller ( forgot the duration ) in a 76 volare. Very dependable and low buck setup running 11.20's in the 1/4. We have a scamp with a stock stroke 5.9, same camshaft and stock magnum heads running 11.40's in the 1/4. Both have holley carbs with an M1 single plane carb. The volare has a stock 904 and 4.30 rear gear and the scamp has a stock 727 with 4.30 rear gear. Both cars are budget bracket cars and run season after season without even pulling a valve cover.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Any 360 Magnum users out there? [Re: StandOnIt] #472283
09/19/09 03:25 PM
09/19/09 03:25 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Nother question, someone said i can longate one of the holes on the magnum flexplate & just use it, but will i need to change the converter to one with weights for the magnum, because i'm sure the 71 318 doesn't have weights on the converter.
Re: Any 360 Magnum users out there? [Re: joedust451] #472284
09/20/09 08:30 AM
09/20/09 08:30 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if you use the later flexplate (not sure if it's 96-up or more like 98 or 99), it has the weight on the flexplate so you use a neutral balance converter. B&M also makes a magnum weighted flexplate for a 727.
since the engine's out of the car, why not get the roller cam reground to something more sporting? it'll be less than $200, and another $100 or so for hughes 1110 valve springs, which can be used with junkyard 2.2L retainers
2017 Grand Cherokee Overland
Re: Any 360 Magnum users out there? [Re: patrick] #472285
09/20/09 10:30 AM
09/20/09 10:30 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
Its a 95, i'll see if theres weights on it. I've thought about doing something with the cam, but money is tight right now, i called hughes to get a cam recammendation, they wanted to put me in something with 560 lift., how much lift can you get regrinding one of these stock rollers?
Re: Any 360 Magnum users out there? [Re: joedust451] #472286
09/20/09 10:49 AM
09/20/09 10:49 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
Using B&M flexplates on both setups.
Re: Any 360 Magnum users out there? [Re: joedust451] #472287
09/21/09 07:27 AM
09/21/09 07:27 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I had my roller cam reground by bullet with their 259/316 lobes for intake and exhaust. works out to .506" lift with mag rockers. I's stick to under .340" lobe lift if you don't want to spend a ton on springs and head machining. for a sporty mag 360, I'd probably go around their HR270/330 lobes for both intake and exhaust
http://bulletcams.com/Masters/HRlobes.htm
Re: Any 360 Magnum users out there? [Re: patrick] #472288
09/22/09 12:54 AM
09/22/09 12:54 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Your biggest roadblock will be the tiny cam the Magnums use.
I have one in a truck and it is a nice combo for a truck. Especially when towing. In a car you'll want to cam it up and trade some of that below 2000rpm action for some 4500 rpm and higher play.
They are also a nice quality engine. I'm not even going to tell you how many miles are on my engine because nobody will believe it. I actually don't either but in 5000km I consume less than a quart of oil and it runs like perfect.
Re: Any 360 Magnum users out there? [Re: Magnum] #472289
09/22/09 01:05 AM
09/22/09 01:05 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
I would get a cam, but hughes wants to put me in something with .560 lift, seems a bit steep for such a mild combo i want, i'm sure with 3.55 gears, it'll run fine with the stock cam for awhile, right now i have 2.76s, that should work really good, i'm bringing the heads in tomorrow & have them checked, hopefully there not cracked .
Re: Any 360 Magnum users out there? [Re: joedust451] #472290
09/22/09 04:32 PM
09/22/09 04:32 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Exactly, how much lift can we have using stock springs ?
Dan
Re: Any 360 Magnum users out there? [Re: Wedgeman] #472291
09/22/09 06:21 PM
09/22/09 06:21 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Had the heads looked at today, he knew exactly where to look, before he even mag'd them, he said "this ones crack", sure enough, cracked big time in-between the intake/exhaust, the other was cracked to, he said they crack at the end chamber between the valves, so now i'm kind-of screwed, i left them there, guess my only option are the Hughes "iron rams", but there out of them, but they have the RHSs for 875.00, i can also get a re-ground cam for 199.00 with my core, its .503 lift, what do you guys think, should i just get the RHSs & a re-ground cam?
Re: Any 360 Magnum users out there? [Re: joedust451] #472292
09/22/09 09:41 PM
09/22/09 09:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Don't try to use the stock springs for any more than stock lift. They are barely adequate for a stock motor when you add a carb and headers. If you want a number I would say .450 , you might be able to sneek out a few more thousands with a flat tappet because it is lighter but then you have to worry about coil bind.
I have a pair of bare aluminum magnums I might sell, PM me if you want some more info.
Re: Any 360 Magnum users out there? [Re: HotRodDave] #472293
09/22/09 10:40 PM
09/22/09 10:40 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
I've had my goods and bads with my Magnum motor, but overall, I like it.
Re: Any 360 Magnum users out there? [Re: Wedgeman] #472294
09/23/09 11:55 AM
09/23/09 11:55 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Dan
.480" at the valve, max from measuring coil bind and IH on my mag heads. but you can't have very aggressive ramps either, as the springs are only like 60lbs seat pressure and 250lb/in rate.
Re: Any 360 Magnum users out there? [Re: patrick] #472295
09/23/09 04:01 PM
09/23/09 04:01 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Just ordered a set of RHS Magnums from hughes for 875.00, others wanted 6-700.00 for stock reman heads.
Patrick, i called Bullet cams, its 125.00 to re-grind mine, but i can only get around .430-.440 lift, for 199.00, hughes will take mine as a core & put me into a .500 lift. They will give me more lift, but i would have to change the springs.
Re: Any 360 Magnum users out there? [Re: joedust451] #472296
09/24/09 09:22 AM
09/24/09 09:22 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
the hughes heads come with their 1110 spring package, which should be fine for any of their cams into the .54" lift range.
who did you talk to at Bullet? I worked with Tim. the first guy I talked to said he didn't think they could put much lobe on mine, Tim said that the OEM Chrysler roller cam cores are hardened much deeper than the GM and ford ones
(in the range of .4" deep), so they can get pretty aggressive on a regrind. he had no problem putting the HR259/316 lobe on mine, and it sounded like I could have gone bigger if I had wanted to. I'd call bullet back and ask for Tim and see what he has to say.
Re: Any 360 Magnum users out there? [Re: patrick] #472297
09/24/09 10:46 AM
09/24/09 10:46 AM
Mooresville, NC
I
I
Mooresville, NC
I used a friends spring pressure tool, but with 15K miles on Sealed Power stock replacement springs I measured 80 on the seat and 270 open. With .060 shim...85 and 280. Still over .060 cbc.This is measuring at stock installed height, btw.
