904 stator support twist ? #472105
09/18/09 09:31 PM
09/18/09 09:31 PM
mid Ga.
W5Dart378 Offline OP
mid Ga.
Over 1 spline, sorry no picture.. Was swapping converters and found this. worst ever. Enyone ever broke one? About to go back together with it.
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s 69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
Re: 904 stator support twist ? [Re: W5Dart378] #472106
09/18/09 09:46 PM
09/18/09 09:46 PM
mid Ga.
mid Ga.
Re: 904 stator support twist ? [Re: W5Dart378] #472107
09/18/09 09:59 PM
09/18/09 09:59 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I had the same thing happen with a 727. The converter I was using was a 9" dynamic. Just think if it was one of those awesome powerglides it would just turn the stator tube in the pump housing.
Re: 904 stator support twist ? [Re: Leon441] #472108
09/18/09 10:15 PM
09/18/09 10:15 PM
mid Ga.
mid Ga.
Well it is going back together, for a couple days.About due for some cluthes I'm sure.
Just want to make a couple passes with the PTC 9" that is a few hundred looser..
Re: 904 stator support twist ? [Re: W5Dart378] #472109
09/18/09 10:58 PM
09/18/09 10:58 PM
mid Ga.
mid Ga.
Leon, have you seen the race coming up in Valdosta in Feb. Do you have stock rear frame rails? You could run the Extreme 275 radial race I beleive.
I could probbly help u out with some tires, just to see your car run and meet you.
I plan to run the other 275 race.
