I Thought Forced Air Induction Was Good? #472086
09/18/09 09:31 PM
09/18/09 09:31 PM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
Well I got to the track, and it was a cool evening (58 degrees). Maybe too cool. Changes since last post: new Mallory made MP distributor, Chrome ECU box and a carb base plate sealed to the hood w/ foam.
Here are the results:
Run #1 Run #2 Run #3
R/T .107 .099 .305 (zzzz)
60' 2.35 2.15 2.34
1/8 9.01 8.67 8.86
MPH 82.91 84.96 84.50
1/4 13.83 13.30 13.48
MPH 101.44 106.03 105.99
Due to a bad track oil down and an hour and a half wait, that's all the runs I got in that nite. The difference between runs #1 and #2and 3, was that I removed the carb to hood scoop base plate and went back to the 14" stock air cleaner. The carb to scoop details are these: 68 style S/S scoop, 15" hole in the hood, flat baseplate w/Moroso flame retardant foam sealing to the hood. I thought 'ram' or forced air induction would be a huge improvement. Too much turbulence? Anyway I'm a bit happy w/ the results considering the track temp and me running on street tires (BFG's), but I want 12's!!!
Post deleted by Defbob [Re: Kudakidd] #472087
09/18/09 09:32 PM
09/18/09 09:32 PM
Re: I Thought Forced Air Induction Was Good? #472088
09/18/09 10:06 PM
09/18/09 10:06 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
might be time to jet up
Re: I Thought Forced Air Induction Was Good? [Re: tjmarcus1] #472089
09/19/09 09:22 AM
09/19/09 09:22 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Jet the carb up and put some M/T drag radials on it and you should have your 12 A 13.30 should have around a 1.85 60ft. Our little 360 Duster runs 12.40's with a 1.73 60ft @ 109 mph. I would think with jetting and tires you could easily run those numbers.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: I Thought Forced Air Induction Was Good? [Re: 67HEMI] #472090
09/19/09 09:45 AM
09/19/09 09:45 AM
Kudakidd Offline OP
Kudakidd  Offline OP
Thanks Wedge. I hear you loud and clear about the 60' times and slicks. But the last car I ran on slicks (68 Charger R/T 440), I started breaking parts(see pressure plate pic below). This Duster will only see the track about 4 times a year.
Re: I Thought Forced Air Induction Was Good? [Re: Kudakidd] #472091
09/19/09 09:56 AM
09/19/09 09:56 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
but I want 12's!!!
Put a small block in it!
man, that sixty foot time is atrocious...I would go drag radials, SS springs, good shocks, etc.
Re: I Thought Forced Air Induction Was Good? [Re: dustergirl340] #472092
09/19/09 10:16 AM
09/19/09 10:16 AM
Is this a 4-speed car??..if so good luck trying to get it to hook on street tires...by the way if you ain't breaking things you ain't going fast..
Re: I Thought Forced Air Induction Was Good? #472093
09/19/09 08:58 PM
09/19/09 08:58 PM
Kudakidd Offline OP
Kudakidd  Offline OP
yeah, it's a 4 gear. And I know the 60' times are really poor, but I tried a number of different launch techniques and haven't had much success with any of them.
Re: I Thought Forced Air Induction Was Good? [Re: Kudakidd] #472094
09/19/09 09:11 PM
09/19/09 09:11 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
with the tires you have im sure your best bet would be to leave on idel and them get after it, that alone should get you a 1.8 60', otherwise get some MT radials as said before and hang on...Thats an easy 12.5 car just need to hook it up.....Phill
Re: I Thought Forced Air Induction Was Good? [Re: 9 Sec Phill] #472095
09/19/09 10:12 PM
09/19/09 10:12 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
i trust you're not lettin off the gas when shifting???
Re: I Thought Forced Air Induction Was Good? [Re: 9 Sec Phill] #472096
09/19/09 11:09 PM
09/19/09 11:09 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Thanks Phill, I try idling out of the hole and see what happens.
TJ, the 'go' pedal doesn't come up until I cross the line at the big end.
Re: I Thought Forced Air Induction Was Good? [Re: Kudakidd] #472097
09/19/09 11:28 PM
09/19/09 11:28 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
specifically between which runs did you swap from one setup to the other?
Re: I Thought Forced Air Induction Was Good? [Re: CokeBottleKid] #472098
09/20/09 09:37 AM
09/20/09 09:37 AM
Kudakidd Offline OP
Kudakidd  Offline OP
the last two(where my mph were 105 and 106)
Re: I Thought Forced Air Induction Was Good? [Re: Kudakidd] #472099
09/20/09 10:10 AM
09/20/09 10:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Kid , as other said you need to jet the carb up , adding all that air made you go lean . You need to come out of the hole on those tires just above idle , as soon as you get moving floor it , but you should get a set of street sticky's if you want to really get all you can out of it. Street radials suck at the track.
Re: I Thought Forced Air Induction Was Good? [Re: JohnRR] #472100
09/20/09 11:35 AM
09/20/09 11:35 AM
What have you got in there for jets now??...
Re: I Thought Forced Air Induction Was Good? [Re: tjmarcus1] #472101
09/20/09 11:51 AM
09/20/09 11:51 AM
WA 98043
thecarfarmer Offline
WA 98043
BTW, my mid-fifteen second Valiant was knocking off 2.21 sixties; I'd agree with all the guys who point to the 60's needing work.
Tried an adjustable pinion snubber? Putting one in, and setting it tight made a difference on my car.
Knocking a couple tenths off that launch will get you real close to the twelve second zone, and your car has enough wheaties to do the job.
BTW, are the tires Radial T/As? It's been twenty years since I ran a set, but my recollection is that they would spin fairly easy.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: I Thought Forced Air Induction Was Good? [Re: JohnRR] #472102
09/21/09 05:22 PM
09/21/09 05:22 PM
Kudakidd Offline OP
Kudakidd  Offline OP
I thought I was doing this technique, but maybe I was still a little 'hot' leaving the line. I try again!
Re: I Thought Forced Air Induction Was Good? #472103
09/21/09 05:26 PM
09/21/09 05:26 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Its a Mighty Demon 750 DP w/ 73's in the primaries and 84's in the secondaries.
Carfarmer, they are BFG radials. How did ya know?
Re: I Thought Forced Air Induction Was Good? [Re: Kudakidd] #472104
09/21/09 05:31 PM
09/21/09 05:31 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
The big difference in your runs was from the 60' not likely the changing to the filter made much difference!
If it was the filter will make it run leaner so maybe you to rich. But was the oil down between runs 1 and 2?? in the evening weather and wind can change a lot and affect a lot??
For instance if you run at 8:00 pm at 75 degrees into a head wind and next run was 9:30 60 deg and winds often go down at dusk so that can be a big performance swing?
