4500 flange M1 intake with a 4150 carb #471980
09/18/09 05:35 PM
09/18/09 05:35 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Wondering if anybody has ever put a 4150 carb on a 4500 intake?
I currently have a 4150 M1 on my motor and it seems to want more plenum, ie it goes faster with a 2inch open over a 1inch open, 4 hole, etc.
So I happen to have a 4500 M1 and the plenum looks bigger on it and Ive got an adapter.
What do you think? Worth trying?
I have the intake off at the moment, so I thought Id swap if it appears to be heading in the right direction.
Any thoughts?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 4500 flange M1 intake with a 4150 carb [Re: Von] #471981
09/18/09 07:59 PM
09/18/09 07:59 PM
AndyF Offline
AndyF  Offline
Sure, it works pretty well. I use a Wilson 4150 to 4500 adapter which is a pretty slick.
