Headin to the strip, 1st time down, what will it run??? #471930
09/18/09 05:09 PM
09/18/09 05:09 PM
Finally a HUSKER again
Moparnut426 Offline OP
Takin the demon up to Marion tonight for t&t. Any guesses what it will run.
Mild 360
Ported "J" heads,
.040 KB pistons,
Internally Ballenced stock bottom end,
9.8:1 comp,
Hydro Roller @50 236/242, .570/.555 comp cam,
833 bash box,
Performer RPM intake,
Quick Fuel 750 carb,
3:91 gears,
ss springs,
pinion snubber,
M/T ET streets...
Any guesses??
Kasey
Re: Headin to the strip, 1st time down, what will it run??? [Re: Moparnut426] #471931
09/18/09 06:59 PM
09/18/09 06:59 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
Depends on how fast you can shift ,but i'd say mid to low 12's in the 1/4 if you shift like you mean it (powershifting).Proly get 7.8's - 7.9's in the 1/8 ,if it hooks well.Hard to predict a stick shift car ,cuz so much depends on the driver .Good luck and have fun ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: Headin to the strip, 1st time down, what will it run??? [Re: The Shocker] #471932
09/18/09 07:06 PM
09/18/09 07:06 PM
owt west
Thread Ender1 Offline
owt west
I'd say if all goes well a 12.10 at 113 or so
Re: Headin to the strip, 1st time down, what will it ru [Re: The Shocker] #471933
09/18/09 07:06 PM
09/18/09 07:06 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The shocker doesn't give you much credit for being able to shift, i'd say you should be able to crack the 11's. Good luck rowin those gears
Re: Headin to the strip, 1st time down, what will it run??? [Re: Moparnut426] #471934
09/18/09 09:05 PM
09/18/09 09:05 PM
Easton, PA
68DART360 Offline
68DART360  Offline
Easton, PA
12.40 @ 110
Re: Headin to the strip, 1st time down, what will it run??? [Re: 68DART360] #471935
09/18/09 09:07 PM
09/18/09 09:07 PM
mid 12's...
Re: Headin to the strip, 1st time down, what will it ru [Re: rowin4] #471936
09/18/09 10:03 PM
09/18/09 10:03 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
I meant no disrespect ,its just that for every guy you see driving a stick car right at the strip nowdays ,you will see 10 that dont.I ran my old stick shift gasser a few years back at a Nostalgia event a few years ago .There were proly a 200 cars racing and half were 4spds like mine was.Myself and one other guy were powershifting ,and that was it.It was sad.I stick it on the floor when i launch a standard car and dont let off till its over.I constantly broke rearends ,ujoints ,etc ,but had a blast in the process.Maybe the guy can shift ,his ET will confirm it if he does ...
Re: Headin to the strip, 1st time down, what will it ru [Re: The Shocker] #471937
09/18/09 11:31 PM
09/18/09 11:31 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
14.30's
Re: Headin to the strip, 1st time down, what will it ru [Re: J_BODY] #471938
09/19/09 12:32 AM
09/19/09 12:32 AM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
Have you ever driven any stick shift car down the strip? Does the car have drag radials?If no to both you gonna start off somewhere in the 13.40s-13.80's and you should work it down into the 12.60s-12.80's once you start getting the feel for it. Godd luck and all that matters is that you have fun.
Re: Headin to the strip, 1st time down, what will it ru [Re: J_BODY] #471939
09/19/09 12:33 AM
09/19/09 12:33 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
14.30's
Spin City
Re: Headin to the strip, 1st time down, what will it ru [Re: MrFoFody] #471940
09/19/09 12:53 AM
09/19/09 12:53 AM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
I agree...mid 13s at best....
71 440-6 4spd & 69 Hemi 4spd
Re: Headin to the strip, 1st time down, what will it ru [Re: hemi_doug] #471941
09/19/09 08:36 AM
09/19/09 08:36 AM
Well Im not disapointed as its the 1st time since I built the car I have gone down the 1340...
My best out of 3 passes, very packed Test and Tune, Was
13.8
60ft time, BAD!!! 2.25
102.97 MPH
Ill try to post the time slips, but they are very hard to read.
I couldnt hook that thing for sh*t!! I Dropped air to 10 PSI, Still spunn like mad..
My 1st and worst pass was
14.48
2.44 60 ft,
101.63 mph
Im proud of myself for shifting well, didnt miss any, and the car realy drove well.
The tires I thought were what was holding me back.
I know I need to learn the launch, but its been a long time. I think with slicks, and If I take the rear clamp off the SS springs it will hook better.
Kasey
Re: Headin to the strip, 1st time down, what will it ru [Re: Moparnut426] #471942
09/19/09 09:32 AM
09/19/09 09:32 AM
Toronto
mshred Offline
mshred  Offline
Toronto
I personally think mid 12's are in it for sure, if not a bit faster...good luck and hopefully the chassis tweaks help out a bit
Re: Headin to the strip, 1st time down, what will it ru [Re: Moparnut426] #471943
09/19/09 09:48 AM
09/19/09 09:48 AM
rowin4 Offline
rowin4  Offline
Now I know why your times were a little slower , you were running 1340 instead of 1320
Re: Headin to the strip, 1st time down, what will it ru [Re: Moparnut426] #471944
09/19/09 09:51 AM
09/19/09 09:51 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Are these ET Street Drag radials? I keep mine at 17-19 PSI and they hook best there.
Also with SS spings on an A body, you may need longer shocks in the back. We switched to Dodge truck shocks and that alone dropped my sixty foot a tenth.
Re: Headin to the strip, 1st time down, what will it ru [Re: Moparnut426] #471945
09/19/09 09:54 AM
09/19/09 09:54 AM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Whats the 1/8 E.T. and MPH and what fuel pump are you running- seems to be 10-12mph off up top, should be good for at least 112mph as is.
Re: Headin to the strip, 1st time down, what will it ru [Re: MoparJoe] #471946
09/19/09 10:20 AM
09/19/09 10:20 AM
10 lbs..put the air back in them,my duster likes 15 lbs..
Re: Headin to the strip, 1st time down, what will it ru [Re: MoparJoe] #471947
09/19/09 10:22 AM
09/19/09 10:22 AM
Well
I didnt get much time to to make more than 3 passes, so I dont hava lot of info, but I am running longer shocks with the springs I think they are Summit brand 90/10s up front, and thematching rear shocks for the car/springs etc. They are made by qa1 I was tolk. I started at 32 psi cause I just wanted to know what it would do in total street trim, Then I ran 17 psi the 2nd pass (which was the fastest) but still a 2.25 60ft, then on the hardest hooking run I dropped to 10 psi.
My 1/8 mile was 1st, a 9.5, 2nd 9.0, and 3rd 9.2...
I have the fuel PSI at 6.5 with my crappy summit guage, and its a new holley fuel pump. Engine Ran great, really great accually. It never nosed over, farted, or even bogged when it did hook in 2nd gear.
Im sure I just have a low MPH due to wicked tire spinn.
MoparJoe, Im sure my mph will come inn.
I have a 408 in the works, and the machining is almost done!!!
Re: Headin to the strip, 1st time down, what will it ru [Re: MoparJoe] #471948
09/19/09 10:27 AM
09/19/09 10:27 AM
San Diego
formula S Offline
formula S  Offline
San Diego
My car went 12.92 113mph with old school L-60-14 tires. Engine was a 360 with a 284/484 cam, ported iron 70 340 heads,victor 340 intake, 800 holley, 1 3/4 headers with c/r 9 to 1 and the timing set at 36 deg total. The car 67 formula S 4.10 gears with a 833 four speed
Re: Headin to the strip, 1st time down, what will it ru [Re: formula S] #471949
09/19/09 10:33 AM
09/19/09 10:33 AM
I really wish I would have had more run time. We are 2 hrs from the track, and I still have to make a living. The 408 isnt cheap.
I know the power was there, I just have crazy traction issues. Im not making any more runs this year, or with this engine, I have a base line, and have the new bullet going in when the snow flies.
I did have a lot of fun, and there is nothing like a mopar in the burn out box posi walkin to the right...
