Differences in a Magnum distributor #471906
09/18/09 05:00 PM
09/18/09 05:00 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
What's different about the distributor that are used on the Magnum motors?
Re: Differences in a Magnum distributor [Re: cruzin] #471907
09/18/09 05:06 PM
09/18/09 05:06 PM
CONNECTICUT
RoyceFlo73 Offline
RoyceFlo73  Offline
CONNECTICUT
I don't know all/any of the differences in the distributors really.
One thing i do know is that the magum's caps have the male plugs for the wires and the LA use the female.
I don't know if they interchange or not. I would assume that they do.
Re: Differences in a Magnum distributor [Re: RoyceFlo73] #471908
09/18/09 05:11 PM
09/18/09 05:11 PM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
You can use it in an LA engine. The biggest difference is the cap and the Magnum distributor is shorter height than the LA distributor.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Differences in a Magnum distributor [Re: maundmotorworks] #471909
09/18/09 05:21 PM
09/18/09 05:21 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
the advance curve also doesn't run by vacuum, it runs from the computer.
Re: Differences in a Magnum distributor [Re: sharpie] #471910
09/18/09 05:26 PM
09/18/09 05:26 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
So does that mean no weights or spring?
Re: Differences in a Magnum distributor [Re: cruzin] #471911
09/18/09 05:29 PM
09/18/09 05:29 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
this is all I know, unfortunately:
"You won't run your Magnum engine with the MPI distributor that comes with it from the junkyard, since the stock units are designed to work with the engine's PCM. Any small-block Mopar conventional distributor will solve that. We used an MSD distributor, though a Mopar Performance electronic-ignition distributor is a popular alternative."
Re: Differences in a Magnum distributor [Re: cruzin] #471912
09/18/09 08:38 PM
09/18/09 08:38 PM
Andrewh Offline
Andrewh  Offline
pretty much empty inside.
A rotor, a shutter wheel and a thing the shutter wheel spins past.
Re: Differences in a Magnum distributor [Re: cruzin] #471913
09/18/09 09:52 PM
09/18/09 09:52 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
the magnum distributor is not a distrubitor in traditional senses. It is used for fuel sync and spark. It will not work as a distributor in a LA motor.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: Differences in a Magnum distributor [Re: blk00rt] #471914
09/20/09 08:24 AM
09/20/09 08:24 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
it's very similar to any lean burn distributor--no mechanical or vacuum advance mechanisms, just a locked out pickup. other than the housing/cap difference, the mag dizzy I have laying around here is essentially the same as the dizzy that came out of my '86 5th ave.
2017 Grand Cherokee Overland
