Which rocker arms #471535
09/18/09 07:20 AM
09/18/09 07:20 AM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
T & D or Harland Sharp Indy 440-1 heads trying to decide which to go with opinions please
1979 W200 470
Re: Which rocker arms [Re: 79_W200] #471536
09/18/09 08:00 AM
09/18/09 08:00 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Need to know what cam and springs you intend to use.
Killer cam + Killer springs = Killer rockers - get the T&D's or Jesel's for sure.
Milder cam and springs = Good rockers - HS should work. Don't buy anything less. Don't buy Indy rockers.
Don't mind spending more for better parts - Get T&D's or Jesel's even if you don't think you need them.
Re: Which rocker arms [Re: GomangoCuda] #471537
09/18/09 08:09 AM
09/18/09 08:09 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
For years I used Indy rockers. They lasted 3 to 4 years, I had a 283 degree .68" lift solid roller. Then I switched to Ersons, really nice rockers and the price was reasonable, unfortunately they donät make them anymore. However, still have them in the engine. Then I decided to try T&D's, for some reason they didn't work in our engine. since they work in many others, I don't think it was because of the design, jsut some "glimps" we didn't catch. After the third major valvetrain failure I buried the T&D's and ordered a set of Harlan Sharps as spare. Hope they'll do their job when the day comes.
Plynouth VIP '67 TT IC EFI
Re: Which rocker arms [Re: jyrki] #471538
09/18/09 10:36 AM
09/18/09 10:36 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
In this order from Best to good..
Jesel
T&D
Harland Sharpe.
Seeing how the Harland Sharpe rockers are almost the same price as T&D..makes it the better choice IMO.
Re: Which rocker arms [Re: Bob_Coomer] #471539
09/18/09 10:47 AM
09/18/09 10:47 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
What's wrong with RAS rockers?
Re: Which rocker arms [Re: 64Post] #471540
09/18/09 11:42 AM
09/18/09 11:42 AM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
Does RAS even offer an offset rocker for the 440-1?
Re: Which rocker arms [Re: camdog440] #471541
09/18/09 02:13 PM
09/18/09 02:13 PM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
Crower solid roller cam #32416 .715 lift 220-250 seat 600+ open plan to be 7500-8000 rpm range what type adjuster does the T&D have ball or cup? i don't have oil through lifters will the be a problem with T&D setup
i didn't think RAS made -1 offset rockers
1979 W200 470
Re: Which rocker arms [Re: 79_W200] #471542
09/18/09 02:31 PM
09/18/09 02:31 PM
KY
juicedcuda Offline
juicedcuda  Offline
KY
I would use the T&D's, shaft mounted. They have cups for adjusters. They will oil through the shaft, so no need for pushrod oiling.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Which rocker arms [Re: 79_W200] #471543
09/18/09 02:41 PM
09/18/09 02:41 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Harland Sharps are more than adequate at that range. T&D is certainly an option, and are nice pieces, but dont worry a bit about running Harlands with those pressures. Non issue.
RIP Monte Smith
