Re: 904 low gear set et pick up
[Re: roadrunnerreds]
#471508
09/19/09 11:50 AM
09/19/09 11:50 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I kind of have an answer for you. I went from a low geared 904 to a 727 and it lost a tenth in the 60 and two or three in the 1/4. This was with the same converter as I just had it switched to a 727 setup. It lost that much ET on the motor and on the nitrous. Bigger nitrous pills got the ET back but the 60 never came back.
68 Barracuda Formula S 340
#471509
09/19/09 12:25 PM
09/19/09 12:25 PM
Posts: 5,895 Florida
Locomotion
The more torque and the less weight your car has, the less a low gear set will help. There are too many variables to give an accurate answer.
[Re: Locomotion]
#471510
09/19/09 12:42 PM
09/19/09 12:42 PM
Posts: 2,527 PA
moparacer
PA
What rear gear do you have in it Brad?
I tried a low set in my Dakota and the Duster and it was a waste of time. Switched them both back the very next week.
Your situation might be different though if your not running alot of gear and street driving it some.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Bad340fish]
#471513
09/19/09 10:51 PM
09/19/09 10:51 PM
Posts: 877 ky
68roadrunner
ky
part of it is all that extra weight slinging around in there on the 727
[Re: Dodgem]
#471516
09/20/09 06:07 PM
09/20/09 06:07 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
What year did Ma make the change in the 904s? Wasnt it around 82-83?
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: bill_greenwood]
#471519
09/21/09 07:52 PM
09/21/09 07:52 PM
Posts: 56 SWEET HOME ALABAMA
ITSDUSTA416
SWEET HOME ALABAMA
The low gear set changes 1st and 2nd gear ratios. stock: 2.45/1.45 low gear planetary: 2.74/1.54 It just changes 1st gear alot more.
71 DUSTER 416 ET 6.33 @ 107 1.33 60FT
[Re: 73swinger]
#471520
09/21/09 08:59 PM
09/21/09 08:59 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I bought mine years ago the lower first and second is noticable. first time I installed it made a bunch of other changes. Drove it street strip for yearsI ended up braking the welds on it when the rear brakes locked on. anyway had it welded and was running 3600 lb gtx 440 11.5 to 1 indy SR heads home ported ultra dyne 263/271 @ .050 with .597/.620 lift 4000 stall would run 11.0's to 10.7's one year i had trans out for freshen I put the gear set back in no other changes as only the tranny came out. then it would run 10.9's to 10.6's. pretty much always a tenth faster than the year before of what I had come to expect and of course PB was .1 faster I now have 4.56 gears so first is like going to 5.10 second like 4.88 and drive course is the same 4.56. you are not in second longer as it is lower geared too. fair drop into third though.
#471522
09/25/09 07:08 AM
09/25/09 07:08 AM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
This was my post on low gear Well I got the magic slips tonite . 32 years and a new milestone started out air wasn't that good head wind . If you saw my past post from saturday I added low gear I picked up 60 ft 1.39 to 1.33 and best 8th mile et from 6.39 to 6.27 Benton. GIR best 1.39 10.12 130. GIR tonite 1.38 8.35 106.74 10.06 130.91 1.35 6.26 107.60 9.96 131.82 1.38 6.29 107.53 9.98 131.43 weather will be a factor on liscense runs now think their will be some jet changing and timing. new slicks will be on friday. THANKS to Dan Smith (qwkmopardan),Gary Heilman,Mark Mareschal,Rick Woosley,Terry Lacy, And Cheryl my wife Looks like MMW will be a fun time. DON
-------------------- update 2009 418" build dan smith built 8in 727 430 dana 2860 lb 3040 lb w driver best to date9/15/09 1.33 60ft 10.12 130.new 9.96 131.82 6.26 111.
Edited by 10 o to go (Thu Sep 17 2009 07:09 AM)
Post Extras:
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
