904 low gear set et pick up #471507
09/18/09 03:43 AM
09/18/09 03:43 AM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
how much et did you gain when you switched to a low gear set in a 904 transmission? just want to know if it`s really worth the effort to put a set in.
Re: 904 low gear set et pick up [Re: roadrunnerreds] #471508
09/19/09 11:50 AM
09/19/09 11:50 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I kind of have an answer for you. I went from a low geared 904 to a 727 and it lost a tenth in the 60 and two or three in the 1/4. This was with the same converter as I just had it switched to a 727 setup. It lost that much ET on the motor and on the nitrous. Bigger nitrous pills got the ET back but the 60 never came back.
68 Barracuda Formula S 340
Re: 904 low gear set et pick up [Re: roadrunnerreds] #471509
09/19/09 12:25 PM
09/19/09 12:25 PM
Locomotion Offline
Locomotion  Offline
The more torque and the less weight your car has, the less a low gear set will help. There are too many variables to give an accurate answer.
Re: 904 low gear set et pick up [Re: Locomotion] #471510
09/19/09 12:42 PM
09/19/09 12:42 PM
PA
moparacer Offline
moparacer  Offline
PA
What rear gear do you have in it Brad?
I tried a low set in my Dakota and the Duster and it was a waste of time. Switched them both back the very next week.
Your situation might be different though if your not running alot of gear and street driving it some.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 904 low gear set et pick up [Re: roadrunnerreds] #471511
09/19/09 06:14 PM
09/19/09 06:14 PM
It depends of course If your not spinning the tires now and it stays hook up with the additional starting line gear ratio it may pick up as little as .04 and as much as .18 Every combination is different so unless you know someone who has the exact same combination as yours and has made the switch so they can say with authority and personal expereince what there results are, you shouldn't and can't really compare someone elses results that isn't like your car BTW, every car that I have ran them in 727s went faster
Re: 904 low gear set et pick up [Re: Cab_Burge] #471512
09/19/09 07:44 PM
09/19/09 07:44 PM
SWEET HOME ALABAMA
I
ITSDUSTA416 Offline
ITSDUSTA416  Offline
I
SWEET HOME ALABAMA
I picked up .04 in 60ft and .03et in the 1/8mi and the car stands up high every pass, footbraking. I wouldn't have my trans built without a low gear set.
71 DUSTER 416 ET 6.33 @ 107 1.33 60FT
Re: 904 low gear set et pick up [Re: Bad340fish] #471513
09/19/09 10:51 PM
09/19/09 10:51 PM
ky
68roadrunner Offline
ky
part of it is all that extra weight slinging around in there on the 727
Re: 904 low gear set et pick up [Re: 68roadrunner] #471514
09/20/09 12:23 PM
09/20/09 12:23 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Thats why I listed that info . I think the .1 in the 60 was all gear ratio IMO.
It was to long ago to remember what it did when I swapped from a standard 904 to a low gear 904 lol.
Re: 904 low gear set et pick up [Re: Bad340fish] #471515
09/20/09 04:24 PM
09/20/09 04:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I picked up a tenth in the 1/4 mile 727 stock gears to 727 low gear set no other changes.
the 904 is supposed to be 1 to 1 1/2 tenths by itself?
Re: 904 low gear set et pick up [Re: Dodgem] #471516
09/20/09 06:07 PM
09/20/09 06:07 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
What year did Ma make the change in the 904s? Wasnt it around 82-83?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 904 low gear set et pick up [Re: 69L78Nova] #471517
09/20/09 11:09 PM
09/20/09 11:09 PM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
It all depends on your combo. One of the side effects of the shorter low gear is that you spend more time in second gear getting down the track. Just my .
Re: 904 low gear set et pick up [Re: Dodgem] #471518
09/20/09 11:28 PM
09/20/09 11:28 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
could you give your combo & Times. I am thinking about low gear set for my 340 street/strip Dart.
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: 904 low gear set et pick up [Re: bill_greenwood] #471519
09/21/09 07:52 PM
09/21/09 07:52 PM
SWEET HOME ALABAMA
I
ITSDUSTA416 Offline
ITSDUSTA416  Offline
I
SWEET HOME ALABAMA
The low gear set changes 1st and 2nd gear ratios.
stock: 2.45/1.45 low gear planetary: 2.74/1.54
It just changes 1st gear alot more.
Re: 904 low gear set et pick up [Re: 73swinger] #471520
09/21/09 08:59 PM
09/21/09 08:59 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I bought mine years ago the lower first and second is noticable. first time I installed it made a bunch of other changes. Drove it street strip for yearsI ended up braking the welds on it when the rear brakes locked on. anyway had it welded and was running 3600 lb gtx 440 11.5 to 1 indy SR heads home ported ultra dyne 263/271 @ .050 with .597/.620 lift 4000 stall would run 11.0's to 10.7's one year i had trans out for freshen I put the gear set back in no other changes as only the tranny came out. then it would run 10.9's to 10.6's.
pretty much always a tenth faster than the year before of what I had come to expect and of course PB was .1 faster
I now have 4.56 gears so first is like going to 5.10 second like 4.88 and drive course is the same 4.56. you are not in second longer as it is lower geared too. fair drop into third though.
Re: 904 low gear set et pick up [Re: Dodgem] #471521
09/25/09 02:31 AM
09/25/09 02:31 AM
Gettysburg Pa
Gettysburg Pa
When i built the transmission i only had the four pinion aluminion plantary gear sets. i have a low gear set in steel cases. i do drive it on the street. it has 4.10`s. did the factory make stock gear sets in steel cases? it has a 1.62 60ft with a 4500 ati converter 12.06 @109mph. Brad
Re: 904 low gear set et pick up [Re: roadrunnerreds] #471522
09/25/09 07:08 AM
09/25/09 07:08 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
This was my post on low gear
Well I got the magic slips tonite .
32 years and a new milestone
started out air wasn't that good head wind .
If you saw my past post from saturday I added low gear I picked up 60 ft 1.39 to 1.33 and best 8th mile et from 6.39 to 6.27 Benton.
GIR best 1.39 10.12 130.
GIR tonite
1.38 8.35 106.74 10.06 130.91
1.35 6.26 107.60 9.96 131.82
1.38 6.29 107.53 9.98 131.43
weather will be a factor on liscense runs now
think their will be some jet changing and timing.
new slicks will be on friday.
THANKS to Dan Smith (qwkmopardan),Gary Heilman,Mark Mareschal,Rick Woosley,Terry Lacy,
And Cheryl my wife
Looks like MMW will be a fun time.
DON
update 2009 418" build dan smith built
8in 727 430 dana 2860 lb 3040 lb w driver
best to date9/15/09
1.33 60ft
10.12 130.new 9.96 131.82
6.26 111.
Edited by 10 o to go (Thu Sep 17 2009 07:09 AM)
Post Extras:
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: 904 low gear set et pick up [Re: 10 o to go] #471523
09/25/09 06:58 PM
09/25/09 06:58 PM
Gettysburg Pa
Gettysburg Pa
I am not really worried if it will go quiker just looking to make it last longer with the steel case plantary gear set. Brad
