Plymouth B-bodies 1/4 glasses #471471
09/17/09 11:58 PM
09/17/09 11:58 PM
Lebanon, TN
bronzegtx Offline OP
Lebanon, TN
I have a 1969 Plymouth Gtx that I am restoring. I put the left 1/4 glass in and when you roll the door and 1/4 glasses up there is about 1" gap between them. I have adjusted them every which way you can and it does not help. Can anyone help?
siscojoey@yahoo.com
Re: Plymouth B-bodies 1/4 glasses [Re: bronzegtx] #471472
09/18/09 12:51 AM
09/18/09 12:51 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Measure the door glass & compare it to the other side... You might have a post car door glass...
Re: Plymouth B-bodies 1/4 glasses [Re: bronzegtx] #471473
09/18/09 12:53 AM
09/18/09 12:53 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
shouldnt there be a seal on the edge of one of the windows?
Re: Plymouth B-bodies 1/4 glasses [Re: 1_WILD_RT] #471474
09/18/09 12:54 AM
09/18/09 12:54 AM
Lebanon, TN
Lebanon, TN
They both measure the same.
Re: Plymouth B-bodies 1/4 glasses [Re: nomore65BelvJim] #471475
09/18/09 12:55 AM
09/18/09 12:55 AM
Lebanon, TN
Lebanon, TN
The weatherstripping is on the back of the door glass.
Re: Plymouth B-bodies 1/4 glasses [Re: bronzegtx] #471476
09/18/09 02:32 AM
09/18/09 02:32 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
siscojoey@yahoo.com
Maybe this is of some help?
Re: Plymouth B-bodies 1/4 glasses [Re: A12] #471477
09/18/09 02:38 AM
09/18/09 02:38 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
There's at least an inch difference between a post and hardtop door glass with the post being shorter as in the photos. You can deffinately see the bottom of the door glass difference if you still have the door panels off.
Re: Plymouth B-bodies 1/4 glasses [Re: A12] #471478
09/18/09 08:06 AM
09/18/09 08:06 AM
Lebanon, TN
Lebanon, TN
I used the original door glass, so I know it is correct. It's like the mounting holes in the 1/4 glass are in the wrong place. The 1/4 glass is sitting about an 1" farther back than other side.
