Lower Radiator Hose - to spring or not to spring? #471258
09/17/09 09:09 PM
09/17/09 09:09 PM
Tennessee
WyleECoyote Offline OP
Tennessee
Is the anti-collapse spring necessary?
The old hose I took off didn't have one and the new hose I bought didn't have one.
I hate to put it all together and then read on here next week how necessary it is and then I won't be able to sleep at night knowing I didn't go find one and install it!
Thanks for input!
Ron
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Lower Radiator Hose - to spring or not to spring? [Re: WyleECoyote] #471259
09/17/09 09:13 PM
09/17/09 09:13 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
It use to be ALL new lower hoses came with a spring already in them.
Not any more
Without it the pump at high rpm's can suck the hose closed.
Not the thing that you would want
If you can find one put it in. I try to save the old ones when ever I can
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Lower Radiator Hose - to spring or not to spring? [Re: moparts] #471260
09/17/09 09:18 PM
09/17/09 09:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Not any more
You can make one by wrapping a peice of wire around a broom stick handle.
Re: Lower Radiator Hose - to spring or not to spring? [Re: Challenger 1] #471261
09/17/09 09:34 PM
09/17/09 09:34 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
Not any more
Re: Lower Radiator Hose - to spring or not to spring? [Re: moparcanuk] #471262
09/17/09 09:44 PM
09/17/09 09:44 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
Age old debate...
You can use them if you want but if the cooling system is flowing properly it shouldn't collapse. My Coronet had the problem and the radiator core was almost totally blocked. When I replaced the core the new lower hose had no spring and was installed as is. I have had no issues with it sense.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: Lower Radiator Hose - to spring or not to spring? [Re: moparcanuk] #471263
09/17/09 09:45 PM
09/17/09 09:45 PM
Tennessee
Tennessee
Would coat hanger wire work?
What about "rusting" of the spring?
Wile E. Coyote
Re: Lower Radiator Hose - to spring or not to spring? [Re: moparcanuk] #471264
09/17/09 09:51 PM
09/17/09 09:51 PM
go to a welding shop & ask them for a single piece of stainless welding rod & as said bend it around a broomstick & install it. Turn the ends in toward the middle so there's no chance if it puncturing the wall. A guy said that they are actually used by the factory only to keep hoses from sucking closed when they vacuum fill the cooling systems & others have stated that worn out hoses can suck partly closed in actual use so make/install one & you can move on to other issues & not have to give it a seconds thought.
Re: Lower Radiator Hose - to spring or not to spring? [Re: RapidRobert] #471265
09/17/09 10:02 PM
09/17/09 10:02 PM
scratchnfotraction Offline
I got flamed last time I posted on this subject
but what RapidRobert said,and for those reasons
some times a hose is just soft and weak,and "IS" the only problem with the cooling system
Re: Lower Radiator Hose - to spring or not to spring? [Re: scratchnfotraction] #471266
09/17/09 10:15 PM
09/17/09 10:15 PM
Tennessee
Tennessee
Why'd you get "flamed"?
Re: Lower Radiator Hose - to spring or not to spring? [Re: WyleECoyote] #471267
09/17/09 10:29 PM
09/17/09 10:29 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes it would, it just won't last as long. I bet it'll last 5 years with the proper anti freeze mixture.
Re: Lower Radiator Hose - to spring or not to spring? [Re: Challenger 1] #471268
09/17/09 10:34 PM
09/17/09 10:34 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Go to the wrecking yard and pull the spring out of another car if you have to.
Re: Lower Radiator Hose - to spring or not to spring? [Re: moparts] #471269
09/18/09 12:51 AM
09/18/09 12:51 AM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Not any more
I'm trying to figure out how the hose could get sucked closed. I think that the cooling system is a closed system with no air in it. Full of liquid coolant. If everything is full at idle engine speed--block, heads, pump, hoses, etc.--which comprise the total volume of the system, and we diminish the volume of the system by collapsing a hose, where does the the liquid coolant go? Does it expand another hose? Liquids, including water and ethylene glycol, essentially are incompressible fluids aren't they? I'm referring to a system with a coolant reservoir and two-way vented filler cap.
Re: Lower Radiator Hose - to spring or not to spring? [Re: DZJim] #471270
09/18/09 06:59 AM
09/18/09 06:59 AM
Tennessee
Tennessee
Not any more
I'm totally agreeing with your logic - only theory I can come up with is its just one of them things that happens; like the SF bridge twisting in high winds or a straw through a tree in a tornado - it musta happened somehow for all them thar springs to go into lower radiator hoses.
Wile E. Coyote
Re: Lower Radiator Hose - to spring or not to spring? [Re: WyleECoyote] #471271
09/18/09 07:18 PM
09/18/09 07:18 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I have had this happen. I went to the local Murray's and found a universal hose with a spring in it that matched, then I took it out and put it in my Mopar hose.
Best theory I had, some of the repro hoses are pretty soft and they collapse as they heat up, from the internal forces.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Lower Radiator Hose - to spring or not to spring? [Re: RapidRobert] #471272
09/18/09 08:02 PM
09/18/09 08:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
did you get the hint?
Don't be the exception.
Re: Lower Radiator Hose - to spring or not to spring? [Re: DZJim] #471273
09/18/09 08:16 PM
09/18/09 08:16 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Not any more
It's really no different than the light in your fridge, you have to take a ride under the hood at WOT to truely know the answer....Barring that...It's all theory and I challenge you to show me...Video would be nice. P.S. I run a spring 'cuz I ain't gonna take that ride
Re: Lower Radiator Hose - to spring or not to spring? [Re: WyleECoyote] #471274
09/18/09 08:32 PM
09/18/09 08:32 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I used a spring and it solved my heating problem in my 512 72 Challenger
Re: Lower Radiator Hose - to spring or not to spring? [Re: WyleECoyote] #471275
09/18/09 09:18 PM
09/18/09 09:18 PM
MNobody Offline
MNobody  Offline
Safe to say you will be using the ACME brand spring
Re: Lower Radiator Hose - to spring or not to spring? [Re: Boise Chall] #471276
09/18/09 09:47 PM
09/18/09 09:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
No, it cured the symptom, you still have the problem.
Re: Lower Radiator Hose - to spring or not to spring? [Re: Supercuda] #471277
09/18/09 10:58 PM
09/18/09 10:58 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
OK every time I post about my car you somehow tie it to a long forgotten problem. Why don't you tell me what my problem actually is you don't give any reason for your comments. Oh please supercuda help me I can't stand it anymore please teach me I can't handle my car running at 175 degrees in 85-90 degree air temp while I am beating the crap out of it. Please explain to me how I can get under 175 degrees on a 85 to 90 degree day even thou it runs perfect at 175. This is your chance tell me what is wrong with my perfect running car so I can fix what's not broken put up or shut up wiener
